These documents agree that voltage sources in parallel (or current sources in series) is a bad idea, although less bad if they have the same voltage. An ideal 2V source will provide 2V no matter what. The same applies to an ideal 3V source. If you connect these in parallel with ideal wires which have zero resistance, than there is somehow a 1V drop across that ideal wire connecting them.
Real voltage and current sources have finite output impedances (think of it as a resistor in series with an ideal voltage source that limits their maximum current). So if you connect real voltage sources in parallel current will flow and voltage will drop over these 'resistors' to equalize the voltage. This could generate heat and may not be healthy for the source, though.
