Author Topic: Black Goop used on PCBs  (Read 11196 times)
Offline peps1Topic starter
  • if you can't open it, you don't own it!
« on: August 09, 2015, 10:59:12 pm »
Was just wondering what the black shiny goop you find on some PCBs is actually made of?
Offline microbug
  • Electronics Enthusiast
Re: Black Goop used on PCBs
« Reply #1 on: August 09, 2015, 11:18:48 pm »
What do you mean specifically? Solid black blobs found on a PCB (particularly one from a cheap product) are likely chip on board ICs. The black substance is made from epoxy glue.
« Reply #2 on: August 09, 2015, 11:29:53 pm »
This type of potting compound, that seems really viscous.
Offline Mephitus
  • Dashing, no?
« Reply #3 on: August 09, 2015, 11:50:30 pm »
As a rough guess, it looks like a silastic (silicone) based potting material.
A true gentleman must be prepared for anything. - Pepe le' Pew
Offline John Coloccia
« Reply #4 on: August 10, 2015, 12:47:45 am »
Just what EEVBlog needs...a Klon thread.  LOL
Lots of different things.  Some people use black epoxy...some black silicone based material as mentioned. You can even use a black hot glue stick. Potting and conformal coat does have a purpose, but as you already know it's being used in this case to try and obscure the circuit. Black epoxy is probably the most difficult to defeat, though I wouldn't know. I've never gooped.  Seems very amateurish to me. I couldn't imagine ever giving a customer a piece of gear that I've purposely made impossible to repair and/or modify. Meh.
« Last Edit: August 10, 2015, 12:52:54 am by John Coloccia »
Offline NeverDie
« Reply #5 on: August 10, 2015, 01:22:45 am »
What about the glob of something on the module on the left?
Is that likely a "chip on board IC" that you're referring to?  Is that an unpackaged die somehow mounted directly to the board, and so the blob stuck on it afterward becomes like an after-the-fact cheap packaging?
« Reply #6 on: August 10, 2015, 01:46:42 am »
 :-DD :-DD :-DD
Man, that made me spit tea all over my keyboard!
I totally agree, my interest is purely a quest for knowledge then any plans to goop tube screamer clones and Joyo pedals!
« Last Edit: August 10, 2015, 01:51:20 am by peps1 »
Offline sleemanj
  • Professional tightwad.
« Reply #7 on: August 10, 2015, 05:16:23 am »
Yes that is a chip on board exactly as you described. Die is glued to the board, then the (gold) bond wires are attached from the die to pads on the board, then a blob of epoxy is slapped on top of it.
Offline krish2487
« Reply #8 on: August 10, 2015, 05:45:57 am »
Just for the sake of completeness :D
https://learn.sparkfun.com/tutorials/how-chip-on-boards-are-made
If god made us in his image,
and we are this stupid
then....
Offline john_p_wi
« Reply #9 on: August 10, 2015, 05:55:57 pm »
+1  BTW, clearly following in the gooping mystique created by Dumble...
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #10 on: August 10, 2015, 06:27:46 pm »
Some enviroments require potting. Water, oil, dust or sand. Sometimes heat. You can make your product a lot more durable.
For diy, you use two-component epoxy. Doesn't fully harden, it stays rubberish. It also only lasts 5 to 7 years before drying out and cracking. If used in environments where it is a bit hot.
If you outsource it, they use polyurethane. Turns into a solid black block. Still a bit flexible, lasts ages.
You can pot top-down into a enclosure, but also using molds.
http://www.purtec.nl/im_el16.jpg
You decrease the repairability figure to 0, removing it requires heat and scratching tools. Only usefull if there is enough time available and money to gain.
Offline old gregg
« Reply #11 on: August 10, 2015, 10:06:02 pm »
 :-DD
As you ask, in guitar pedal is more about hiding the "uber-original idea of cloning old circuits as million other do already" than nothing else. Last time I checked, the "Vertex gate" was very funny as well.
Yep Chip on board. No die, direct on the circuit board. The goop is here to protect the all mess.
