Author Topic: Learning PIC "language" for a complete noob  (Read 3037 times)
Offline joblessalexTopic starter
« on: September 04, 2012, 07:16:38 am »
Hello guys! I just picked up a kit and have a lovely PIC16F627 in it to program. I have no idea where to start, and Google turns up more gibberish than I can understand! The kit came with absolutely no documentation, and I had to solder things in by one overhead picture of the stupid thing! Needless to say it works, but where to go for beginner programming lessons? I know a bit of things on Arduino, but no real coding. Thanks! Also, if you see this Dave, UNBLOCK ME ON YOUTUBE! (please?) I don't know what I did, but I can't comment anywhere!
« Last Edit: September 04, 2012, 07:31:23 am by joblessalex »
Offline Rerouter
Re: Learning PIC "language" for a complete noob
« Reply #1 on: September 04, 2012, 07:35:40 am »
http://www.winpicprog.co.uk/pic_tutorial1.htm
may as well start off where you most likely began on arduinos, hope it helps :)
Offline notsob
« Reply #2 on: September 04, 2012, 07:59:02 am »
Offline Bloch
« Reply #3 on: September 04, 2012, 08:09:06 am »
A noob and "no documentation" is a bad combination  ;)
I would suggest buy a Pickit2 or Pickit3 http://www.microchip.com/pickit3
Offline amyk
« Reply #4 on: September 04, 2012, 08:23:05 am »
As always, refer to the datasheet to get really familiar with all the subsystems.
http://ww1.microchip.com/downloads/en/devicedoc/40300c.pdf
Don't forget to look over any errata too.
Offline Colin55
« Reply #5 on: September 05, 2012, 11:37:16 pm »
http://www.talkingelectronics.com/
has all the resources you need.
« Reply #6 on: September 08, 2012, 12:52:49 am »
Thank you for all of the information! I will be getting the kit in a while after returning the dogey kit I got! It only works on legacy serial ports, not adapters and as such was useless!
Offline westfw
« Reply #7 on: September 08, 2012, 01:35:06 am »
http://jaluino.org/ ?
I second the recommendation for WinPicProg...
(People underestimate how important the USB port on Arduino was.  Or the bootloader in general.)
Another suggestion: USB Bit Whacker.
« Last Edit: September 08, 2012, 01:49:05 am by westfw »
