Author Topic: Video sender PA  (Read 1720 times)
Offline @rtTopic starter
Video sender PA
« on: May 27, 2017, 01:06:09 am »
Hi Guys :)
I was hoping for some tips with regard to a simple VHF video sender PA part.
There are schematics out there, but I'm starting with an already working universal modulator.
The first I've tried is a 2N3904.
It appears the RF from the modulator cannot switch the transistor.
My scope backlight shat itself last night, so I can't even look at it.
I only want to use a low power amplifier for a range of a few meters.
Cheers :)
Edit, Changing the 2N3904 to 2N2222, this is the first time I’ve got a signal out of the antenna end.
I still have to touch the antenna to it or be very close though. Far from a transmitter.
« Last Edit: May 27, 2017, 02:37:09 am by @rt »
