Author Topic: Why does an LED act like this?  (Read 3137 times)
Offline Falcon69Topic starter
« on: November 24, 2014, 08:04:41 pm »
Okay, I've experienced this numerous times, and I don't know what's happening.
I have an 0603 LED soldered to a circuit board I am working on. When I place my multi-meter on the diode setting and test the LED when it is NOT soldered on the board, it lights up.
However, when I solder it to the board, it does not. So I unsolder it from the board and connect to the multi-meter.  It works again.
Why does it not light on the circuit board when the multi-meter's leads are connected directly to the cathode and anode of the LED?
Thanks in advance for your input in clearing up this mystery.
Offline Mr.B
Re: Why does an LED act like this?
« Reply #1 on: November 24, 2014, 08:07:01 pm »
You would need to show us more of the circuit.
What other components are having an influence on the test conditions...
« Reply #2 on: November 24, 2014, 08:08:40 pm »
Possible you have a pad extending under the LED and shorting it out. Check resistance across the device in circuit to see.
« Reply #3 on: November 24, 2014, 08:34:12 pm »
well, it is connected to a rather large set of traces (1mm then branches off to rest of circuit at .6 and .4 and .4 and .4).   then is connected to a voltage regulators output.  Could it be reading resistance off all that?
It lights up perfectly fine if I connected 5 volts and ground across it.  But doesn't light when a multi-meter is connected (using it's diode output)
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #4 on: November 24, 2014, 08:40:55 pm »
Have a schematic?
Alternate component loading on diode test function of your meter?
Recharged Volt-Nut
Offline Zero999
  • 0999
« Reply #5 on: November 24, 2014, 08:52:57 pm »
Have a schematic?
I'd suspect that's the most likely reason why this is happening.
« Reply #6 on: November 24, 2014, 09:17:11 pm »
okay, that makes sense.
Maybe the added resistance of the traces and the other components in-line are effecting the current through the Multi-Meter and it isn't supplying enough current to light the thing.
I have 16 other led's in the circuit, and they light up with the multi-meter, however, they are not connected to as many components are such large traces.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #7 on: November 25, 2014, 04:34:40 am »
Multimeter red-black is often the opposite voltage polarity in diode test mode (electron flows vs current flow).
But providing a circuit would be a good starting place for us to comment.
Remember your meter may also source more current than the LED wants to see - so it may work (for a little while) but not in the future.
Don't ask a question if you aren't willing to listen to the answer.
