Author Topic: Can some one check if my Arduino Nano V3 circuit will work as intended?  (Read 3646 times)
Offline whileloopTopic starter
I'm working on a robot project. I will program these pins on the Arduino IDE:
IR Distance Sensor -> A0
bottom servo -> 10
top servo -> 9
left servo -> 11
top photoresistor -> A1
bottom photoresistor -> A2
The servos are rated for 5-7 volts, and the IR sensor is also rated safe at 5volts. The photoresistors are within the rated voltage range as well.
What I'm most confused about is the power supply. I will have the 5 volt (+) connected to the VIN, and the GND to (-). Is this the proper setup?
Will my configuration work as intended?
Thank you for your time
Circuit Photo: http://epicness.us/img/circuitDiagram.png
Arduino Nano V3 photo (without circuit): http://epicness.us/img/nano.png
