Author Topic: Making my own own analog RGB cable  (Read 1614 times)
Offline LegionTopic starter
« on: June 01, 2014, 03:45:47 pm »
I'd like to make my own RGB cable for my Sega Master System. It goes from an 8 pin DIN to 4 BNC and 2 RCA. I can't directly solder 4 coaxial cables directly to the DIN connector as the cables are too bulky. What's the best way to solder all those cables to the DIN plug without introducing a lot of noise or interference to the signal?
Re: Making my own own analog RGB cable
« Reply #1 on: June 01, 2014, 03:58:17 pm »
Kill a cheap VGA cable and use the 3 shielded inner cables for the RGB and leave the other 2 to use the outer shield. That should be thin enough to fit in the connector if you use a thin cable, and the other end can go into a bigger box to joint to either BNC and RCA sockets or just to join to thicker shielded cables.
Offline Richard Crowley
  • KJ7YLK
« Reply #2 on: June 01, 2014, 04:01:18 pm »
Use smaller coaxial cable.  You may have to get a consumer RGB cable and chop the RCA connectors off the Sega end.
