Hi all,
I realize there is another thread below this one on a similar topic, but I'm asking different questions.
I recently picked up a few rolls of probe wire (soft, silicone insulated, very flexible, labeled probe wire). I forget what the part number is (I'm at work at the moment.) I want to make myself a good variety of bench connections/leads. Not just for measurements, but also for connections to power supplies. I quick search online shows that test probe wire varies from "a few amps" to 6A (max I've found).
My question is this, would you just use the probe wire to make the power connection wires or simply buy some other wire? In the latter case, what wire would you suggest? I have a few power connection wires currently, but they're just normal stranded pretty thick wire. I generally use it for my battery charger, which can draw a good amount of amps in certain cases. It's just getting annoying switching them back and forth.
