I'm experimenting with a water pump. Its specs say that it can pump water up a 3m height but I only get around 0.5m.
The pump's specs are: 12V, 1.8A
The PSU's specs are: 12V, 2.5A, 60VA
The PSU is a standard brick of the type that is used for laptops.
This is the pump:
https://www.sparkfun.com/products/10455I measured the voltage at 12.3V but the current was only 0.33A
I measured the pump's resistance to be 2 Ohms but presumably as soon as it starts spinning the inductance will cause the motor to have a higher resistance.
Even though the PSU is rated for up to 2.5A, why do I only see 0.33A?
Should I simply buy a new PSU but with 6x the current rating?
