Author Topic: Best genral purpose power mosfet.  (Read 3960 times)
Offline David97Topic starter
« on: July 18, 2014, 01:36:10 am »
Hi everyone (1st post). I'm looking for a inexpensive power mosfet for testing and for projects. The purpose is to control medium to large loads such as motors. An example is a project I'm working on now, where I need to switch a cars ignition coil on and off using a 555 timer to make a pulse jet igniter. I have also been experimenting using windsheild wiper motors for robots, and need a suitable fet to do this. I know I haven't given much info, but I just need something in my parts draw for these types of applications.
Looking to make a bulk order of both N-channel and the P-channel equivalent.
Thanks for any help.
Offline TerminalJack505
Re: Best genral purpose power mosfet.
« Reply #1 on: July 18, 2014, 02:57:06 am »
I'd vote for IRF530 and IRF9530.
Edit: Said IRF930 but meant IRF530.
« Last Edit: July 18, 2014, 03:19:49 am by TerminalJack505 »
Offline kingofkya
« Reply #2 on: July 18, 2014, 04:19:11 am »
I like to have to have a selection:)
I have been useing these guys for common parts lately:
http://www.taydaelectronics.com/
There is quite a few cheap ones to get you started you may want to do a search on whatever you order to make sure its not a discontinued model though.
Offline David Hess
  • DavidH
« Reply #3 on: July 18, 2014, 05:37:35 am »
Driving an ignition coil and switching a motor are different enough that I would want to use different parts or at least different switching circuits.  An ignition coil in particular is a good place for a MOSFET to drive a bipolar cascode switch although in that case the MOSFETs could be similar.
MOSFETs do not have complementary pairs to the extent that bipolar transistors do.  For a given voltage and die size which determines the wattage and gate charge, the P-channel MOSFET will have a significantly higher drain to source resistance and lower current rating.  For equal drain to source resistance, voltage, and current ratings, the N-Channel MOSFET will have a smaller die size yielding lower wattage and lower gate charge.
So for linear applications I pick MOSFET complementary pairs by matching their power rating as a proxy for die size.  In switching applications where rated power dissipation is usually irrelevant, I pick them based on voltage and current.
As far as finding a low cost generic part, I would just search Mouser or Digi-Key or similar for P-Channel devices in TO-220 packages and sort by price and then look for the N-Channel part matched by power for analog and current for switching.
« Reply #4 on: July 18, 2014, 10:19:36 pm »
Thanks everyone.
Offline rob77
  • Country: sk
« Reply #5 on: July 18, 2014, 11:31:43 pm »
i like the hexfets from IR.
IRFZ34N N-chan + IRF9Z34N P-chan
the IRFZ34N has a relatively low gate capacitance - approx. 700pF , so it's easier to drive them with "weak" outputs.
Offline retrolefty
« Reply #6 on: July 18, 2014, 11:48:34 pm »
"logic level" power mosfets are nice if you need to interface with TTL digital output voltage.
