I would recommend you the Brymen235. (Yes - That is the EEVBlog DMM!)
Look here:
Welectron Brymen BM235Consider: The high quality test leads (silicon wires, threaded 4mm banana plugs) are already included.
(BTW: A carry case, too.)
Yes: Instead of 22000 counts you have "only" 6000.
But the DMM is much safer, better build and much more reliable.
And you have a usable warranty if needed. With imported stuff from China it is difficult...
The "pimped-to-be-safer" european GS-version of the UT61E (only CAT III 300V, CAT II 600V!) is not much cheaper as the Brymen.
A review of the BM235:
Dave´s version of the manual:
Download ManualI am pretty sure: Lightages can answer you every question about the BM235.
