Hello, I'm new to electronics. I own two compaq ATX power supply to be specific the: Compaq ps-5201-4t2.
I tried to find schematics on the web but without success.
It has a 20 pin P1 connector. I tried to use a generic pinout for a general ATX power supply but is not starting without the mo-bo connected.
I thought it needs some loads, so I used 10 Ohm 5W resistors on 12v and 5v rails. Still nothing.
I also tried to put such load on the 3,3 V rail from the P1.
As I said the colours of the wires are different, but I tried them by analogy.
Whatever I do, I can't start the power supply. Any ideas?
I'm quite disperate. I want to use it to make a bench power supply.
Can anybody tell me the pin configuration of the 20 pin compaq PS-5201-4T2?
I've seen they are using separate colour form a standard 2o pin ATX power supply.
They are the same pins but with different colours?
Where should I put loads to start it without the mo-bo?
Thanks!
