Author Topic: Understanding laser diode power consumption.  (Read 283 times)
Offline thescientist1064Topic starter
« on: September 07, 2024, 10:39:37 pm »
Hello everyone!
I have a laser diode which generates a 65 W peak power when driven with a 20 A (at 9.5 V) pulse (100 ns, 0.01% duty cycle). Given that the diode is rated for a total electrical power of 20 A x 9.5 V = 190 W, will it draw this much power when operated at a pulsed mode?
FYI, chat GPT claimed that the current needed would only be 2 mA (= 20 A x duty cycle). So I am confused.
Any help would be greatly appreciated. Thank you!
Online Xena E
Re: Understanding laser diode power consumption.
« Reply #1 on: September 08, 2024, 05:05:11 am »
Hello everyone!
2mA is the average current over time. It's irrelevant to the operation of the laser.
The total power consumed over time will be ≈ 19mW.
The PS will still need to be able to pulse the laser at 20A/9.5V. For the rated maximum output power.
Regards,
X
« Reply #2 on: Yesterday at 03:00:55 am »
Thank you Xena, for the comment!
Yes, my driver (LDP-V 240-100, manual attached here) is capable of providing up to 240 A pulses.
Its super counterintuitive that the driver only takes in a low electrical power (19 mW) to deliver such a high pulse power (65 W). So if I am understanding it right, I still need a peak current of 20 Amps (at 9.5 V) to drive my diode but the average current drawn from my power supply will be close to 2 mA (20 A x Duty cycle)?
Online Xena E
« Reply #3 on: Yesterday at 06:46:38 am »
Yes! You got it.
Making that large current available isn't a great problem of course.
The secret sauce is in the delivery to the laser but that's a well trodden path, and all that's needed is to follow the prior art, and use the components as directed.
A few years back, we used a similar component in a targeting system for a mining application. The emitter was driven almost fully, but the device was powered from a 1604/6F22 disposable battery.
