The start and stop bits are overhead on top of the useful data, but the baud- or bit-rate isn't concerned with that.
Baud rate is how many times the signal actually changes per second.
Bit rate can be higher (like QAM256), the same (like UART signals, including RS-232 voltage levels) or lower (like 10/100 Mbit Ethernet), depending on the type of modulation.
