Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Question about T4148 diode
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Question about T4148 diode (Read 612 times)
bshi02
Regular Contributor
Country:
on:
May 21, 2024, 04:33:19 am »
I have 29 inch CRT TV which only display black screen.
After I switched on it and I heard inrush of current,I measured voltage of pin #9 of STR-S6707(6.2-6.4 DCV). and I found that DCV(placing red probe to cathode terminal of diode) of ZD808(it is written B75 on its surface) was 6.8-7V and D805 and positive pin of C811 was 6.4-6.6V , D807 and positive pin of C812 was 13-13.2V, But D806(it is written T4148 on its surface) was 0.5-0.7V like below schematic which I drawed STR-S6707 and its adjacent components in circuit . It is doubt whether D806 is faulty diode or not.
Logged
m k
Super Contributor
Country:
Re: Question about T4148 diode
Reply #1 on:
May 31, 2024, 12:11:09 pm »
STR-S6707 datasheet covers STR-S6709.
Maybe it's demo circuit can give some thoughts.
Logged
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
kevin.gibbs
Regular Contributor
Country:
Reply #2 on:
August 22, 2024, 02:10:18 am »
In general, 0,5-0,7V should drop on the diodes. Therefore, it is likely in good working order. You can unsolder one of the leads for complete confidence and then check the diode with a multimeter.
Logged
Teardown, research, create!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
