Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Single ended signal on PCB
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Single ended signal on PCB (Read 564 times)
Vcky_electro
Contributor
Country:
on:
June 13, 2019, 12:19:39 pm »
I have designed board, in that due to board room limitation we cant achieve 50ohms impedance for single end signal. 60ohms is possible in that design, so what would happen if we use 60ohm impedance trace instead of 50ohm trace..
Regards,
Vicky
Logged
Raj
Frequent Contributor
Country:
Self taught, experimenter, noob(ish)
Re: Single ended signal on PCB
Reply #1 on:
June 14, 2019, 05:43:02 pm »
you'll have to change your termination method, that's it
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
