Thanks for your reply. I shall divulge...
I have an Audison Bit One (12V Digital Signal Processor for automotive use) which outputs a 'trigger' for turning on multiple amplifiers, fans and a 12V DC-DC USB charger (down converts to regulated 5V for powering a Nexus 7, USB hub, powered hard drive).
Problem is, this trigger is limited to 20mA. I want the 'best' (read: easy and efficient) way of achieving this, basically.
Having reconsidered, there isn't any reason this circuit can't appear on the low side. I've been looking for relays with a higher coil resistance but the most common type that are easily accessible are around 80-90ohm, with capacity to switch 30-40A which is right on the money.
I hope that helps!
Thanks again.
