Author Topic: High DC voltage conditioning circuit how does it works ?  (Read 276 times)
Offline IGBTSiCTopic starter
« on: June 28, 2024, 10:24:57 am »
I have found DC VOLTAGE CONDITIONING circuit in "25kW WolfPACK FM3 Six-Pack Inverter" from Wolfspeed eval board. I do not understand how does it works because I have always use voltage measurement with galvanic isolation e.g. based on AMC1200.
DC voltage is not connected with signal ground elsewhere. Why they do not use the parallel resistor Rs (marked in red color on the figure) for voltage droop? Could someone explain how this measurement circuit works ?
Offline Andy Chee
Re: High DC voltage conditioning circuit how does it works ?
« Reply #1 on: June 28, 2024, 10:31:40 am »
This is just a differential amp configuration with a really, really, really big voltage divider.
https://www.electronics-tutorials.ws/opamp/opamp_5.html
The following users thanked this post: IGBTSiC
« Reply #2 on: June 28, 2024, 10:40:13 am »
Thanks, but it has no difference that in circuit from wolfspeed they connected resistors R37 and R153 directly to the inputs of OA ? In differential amp. configuration, the R1 and R2 are connected from the source side. The gain will be the same i.e. Vo = R3/R1 (Vin+ - Vin-) ?
« Last Edit: June 28, 2024, 12:30:11 pm by IGBTSiC »
« Reply #3 on: July 01, 2024, 12:49:46 pm »
I have done the simulation in LTSPICE. Yes exaclly this is the diferntial aplication of OA. Thank you.
