Author Topic: What are these components?  (Read 1796 times)
Offline AlxDroidDevTopic starter
  • Country: br
    • Arduino Web Brasil
« on: November 25, 2015, 04:37:10 pm »
The pics below are from a board taken from a fax machine.
The components I need help identifying are the ones looking like tiny vacuum tubes, but with only 2 legs. They are 13mm tall (not including the legs) with a diameter of 5.5mm. Their legs are in holes that seem to be 200mil apart (~5mm)
They have the lines "351M" and "TM1 J" on them. The light grey socket near them is a RJ11 socket. The small rectifier bridge marked Z61D on one of the pics is just a tad shorter than an optocoupler, and the same width.
I have no idea what these components are, since I've never seen one of these before (that I can recall).
Thank you.
« Last Edit: November 25, 2015, 04:38:58 pm by AlxDroidDev »
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline bktemp
Re: What are these components?
« Reply #1 on: November 25, 2015, 04:40:06 pm »
Those are gas discharge tubes, used for overvoltage (lightning) protection.
The following users thanked this post: AlxDroidDev
Offline Andy Watson
« Reply #2 on: November 25, 2015, 04:45:51 pm »
Voltage surge suppressors. Some form of gas-discharge bulb - not unlike a neon indicator.
Similar to these:
http://www.cdiweb.com/datasheets/okaya/1p132-133rac6.pdf
  • Country: br
« Reply #3 on: November 25, 2015, 04:47:59 pm »
Similar to these:
Thank you!
