Author Topic: Op-Amp  (Read 3206 times)
Offline SamwelTopic starter
  • Country: mt
Op-Amp
« on: June 12, 2016, 10:35:21 pm »
Hi, I am trying to understand how to use an op amp. My question is, can I use an op-amp as a voltage booster ?
Thanks alot
Offline Aodhan145
Re: Op-Amp
« Reply #1 on: June 12, 2016, 10:51:28 pm »
No not really an opamp can only give out voltages within its supply rails, but you can set up a oscillator to drive a switching regulator to boost voltage, but you need to know how op-amps work.
Watch this video. If you still do not understand it watch it again and again and again.
I have personally found it very useful.
The following users thanked this post: Samwel
  • Country: mt
Re: Op-Amp
« Reply #2 on: June 12, 2016, 10:55:04 pm »
Thanks a lot. I will definitely find this video useful.
Offline rstofer
Re: Op-Amp
« Reply #3 on: June 12, 2016, 11:44:53 pm »
Thanks alot
Under conditions as shown in the video, the output voltage from an op amp can be larger than the input.  Whether that is a 'voltage booster' or not, I don't know.
What exactly are you trying to accomplish?
Offline danadak
Re: Op-Amp
« Reply #4 on: June 13, 2016, 10:17:51 am »
As the previous poster noted an OpAmp at its most basic function is
an amplifier. So Vout = G x Vin or -G x Vin.
So in a sense it could be considered as a "booster".
Generally though a booster would be though of as a power booster,
and for that a switch mode power regulator chip/circuit is the solution.
An OpAmp can be used as a power booster, there are actual power
OpAmps for that purpose.
Regards, Dana.
Offline Ammar
Re: Op-Amp
« Reply #5 on: June 13, 2016, 12:43:13 pm »
Not really. You cannot go above your supply rails for your output voltage. Try a boost converter instead.
Offline danadak
Re: Op-Amp
« Reply #6 on: June 13, 2016, 09:56:52 pm »
Original poster has no constraint that he is trying to go outside
supply rails.
Regards, Dana.
Offline Aodhan145
Re: Op-Amp
« Reply #7 on: June 13, 2016, 11:48:22 pm »
Yeah I realised that after I posted that it can be interpreted both ways.
Offline ebclr
Re: Op-Amp
« Reply #8 on: June 14, 2016, 12:12:07 am »
But you can go outside the rails with OP, just make a  square wavee oscillator ( comparator with RC feed back ), and with some diodes and caps you go easily out of the rails positive and negative
Offline eetech00
Re: Op-Amp
« Reply #9 on: June 14, 2016, 12:33:38 am »
Thanks alot
There are different opamp configurations. A "non-inverting opamp configuration" can be use to amplify an input voltage, but not beyond its own power supply input rails.
Offline Synthetase
    • Synthetase's World of Nerd
Re: Op-Amp
« Reply #10 on: June 15, 2016, 07:27:35 am »
Thanks alot
Have a read of this as well, then get your bread board out and start playing with them.
Offline danadak
The following users thanked this post: ebclr
