Hello all, I am new to the site. Haven't found an intro area so I figure I will tell a little about myself here. I have some experience with analog electronics, as a kid I messed with whatever I could take apart and solder back together. About 10 years ago I bought tons of resistors/caps/switches/leds from tayda and have used that stock to fix the occasional good score from the dump like some stereos or electric keyboards and then usually give them away. For a while I would reformat computers with linux and set them up for people, mostly old ladies. I used to work for an electrical device manufacturer, first in production but then I was quickly moved to be the prototype technician working for the engineers making prototypes and also doing quality control on incoming/outgoing materials and products. It was a rather small operation and they weren't too interested in educating me.
Fast forward and I have been a plumber for nearly 10 years. I miss using accurate test equipment. I recently decided to buy a good DMM. I wanted an 87vMAX or a bm896s but ended up with a used/mint 87III from ebay for 200$ shipped. Currently I use an IDEAL 61-746 For work but it doesn't exactly inspire confidence and the measurements tend to jump around. I've had it for most of my tenure and it's proven adequate, but I really want something nicer.
Obviously the 87III doesn't have a builtin amp clamp and I test a lot of pumps and motors so I need one. I was looking at the Fluke I400 and it seems like the best option for high current but I don't usually go above 100amps and for 140$ I can't help but take a real hard look at some of the older amp clamps I find on ebay. I also worry that a 0-400amp clamp won't be as accurate as a 0-100amp option.
Unfortunately most of the stuff I work on is just over the limit of using the internal shunt on a meter(15-25amp range115/230v) and even though some meters can take that for short periods I need something that I can leave connected for more than that without worrying about blowing a fuse or overheating an internal shunt. This is why I am also looking at separate shunt or current transformer. I don't have to use a clamp as 99% of the time I am already disconnecting wires anyway, feeding one through a torroidal current transformer or wire nutting it to a custom box with torroid inside and some test plugs would be just fine.
Safety is not an issue here, I can follow instructions and if you tell me how to do something dangerous correctly I can do that. I mention this because I know that current transformers will have high voltages on the secondaries and this bothers some people, I am not one of those people.
