Author Topic: Should I tear this apart to see what in going on?  (Read 811 times)
Offline larryblTopic starter
Offline themadhippy
Re: Should I tear this apart to see what in going on?
« Reply #1 on: November 18, 2020, 01:21:33 am »
my money is one the discharge resistor across the capacitor dropper has failed
Online wraper
  • Country: lv
« Reply #2 on: November 18, 2020, 01:23:22 am »
Not failure and not that weird. Some bulbs experience this while smoothing capacitor after rectifier is discharging.
EDIT: If you run it without a long cable, it probably will stop doing this.
« Last Edit: November 18, 2020, 01:33:29 am by wraper »
Online wraper
  • Country: lv
« Reply #3 on: November 18, 2020, 01:25:03 am »
There is no capacitor dropper, it's not the cheapest shit from China without any real LED driver where this effect is actually impossible.
« Reply #4 on: November 18, 2020, 01:58:12 am »
This was in a kitchen light, It came on at 1/2 brightness as the other light. Told my wife to turn it off so I could replace it. It stayed lit after being turned off. I replace it in the kitchen, and brought the bulb to the shop to see if I could document the failure.
« Reply #5 on: November 18, 2020, 01:59:40 am »
so, is a tear down warranted?  Or should I just toss it?
Online wraper
  • Country: lv
« Reply #6 on: November 18, 2020, 02:09:40 am »
So if it does not work properly when powered, it's just a faulty bulb. You can tear it down but there is nothing fancy inside. This might be simply one of the LEDs dying.
Offline HwAoRrDk
« Reply #7 on: November 18, 2020, 03:05:01 am »
Huh, what a coincidence, an LED bulb in my bathroom failed the exact same way the other day. Although, wasn't actually half brightness, but flickering very fast. Came on fully for about 2 seconds when switched off.
