Author Topic: Audio Grade Capacitors. Marketing Bull?  (Read 9830 times)
Offline andrewkirkbyTopic starter
« on: May 28, 2013, 06:58:37 pm »
I pretty much asked the question in the subject.
I'm replacing 2 x 10,000 uF 63V Capacitors in my old home cinema amplifier. It's showing signs of psu issues and those look to be the culprit.
My question is, are the 'audio' grade caps really much different to standard ones? I can easily obtain that value of electrolytic from mail order suppliers here in the UK but can't find anything specifically designed for 'audio' use.
I am a sound engineer by trade and I do care about the sound quality out the back but there's a lot of marketing wank out there and want to be sure before I pay more to import something or go further afield..
The ones in it are Samwha branded and it's a Denon amp.
Offline madires
  • A qualified hobbyist ;)
Re: Audio Grade Capacitors. Marketing Bull?
« Reply #1 on: May 28, 2013, 07:25:04 pm »
You don't need to fail for audiophoolery caps :-) Standard caps from well known vendors are fine.
Offline Lightages
  • Canadian po
« Reply #2 on: May 28, 2013, 07:34:19 pm »
There are some arguments for certain types of capacitors to be used in the signal path of some amplifiers. For a power supply there is no argument for any "audio" grade capacitor. Use a capacitor that has a voltage rating of at least 30% more voltage than it will handle and, for a power supply, a low ESR type could be advantageous.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #3 on: May 28, 2013, 07:35:25 pm »
Fit some sweet Panasonics in there.
« Reply #4 on: May 28, 2013, 08:10:21 pm »
Yeah RS do panasonic caps of that value for £3.50 each.
The ones I'm replacing are labelled 63WV 10,000 uF. What's the W?
Also 'DL 85degC (M) Guess that's the model and heat tolerance..
Offline daveshah
  • Country: at
    • Projects
« Reply #5 on: May 28, 2013, 08:30:47 pm »
WV probably stands for working voltage
Offline dr_p
« Reply #6 on: May 28, 2013, 08:31:00 pm »
Working Volts
Offline ConKbot
« Reply #7 on: May 28, 2013, 08:35:10 pm »
"WV" is generally "working volts" or "working voltage"  I.e. the caps will have a surge rating thats somewhat higher than the working rating, but can only handle 63v at the rated temp at the rated ripple etc. to get the rated lifetime spec.
« Reply #8 on: May 28, 2013, 08:51:03 pm »
Gotcha.. So surpass that rating by a factor of ? and  you can substitute in a standard cap just fine.
Offline mariush
« Reply #9 on: May 28, 2013, 08:56:28 pm »
Measure the diameter and determine how the capacitor is connected to the board (normal leads, screw types etc). Then try to get 10000 uF 80v, if you can't find any matching requirements i mentioned, use 63v capacitors. If you still can't find, you could probably go down to 8200uF (or other values closer to 10000 if they exist) but you may have problems getting the maximum voltage out of your amplifier in that case (or get distortion at high volumes)
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #10 on: May 29, 2013, 07:45:36 pm »
Yes, they are special (kind of). Their internal resistance (ESR) is significantly smaller over the audio band, and in some circuits, that might have an effect. On the other hand, quality capacitors made today are better than some years ago. (Sadly, crappy parts are much crappier.) Besides, if the choice is between an amp that does not work at all and an amp tbat does not sound quite as good as ot dos as new...
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
« Reply #11 on: May 29, 2013, 11:43:19 pm »
As an Audio Engineer, I'm far more of the opinion that better or equal to what it was is the only route. I hadn't taken esr into account though. Makes sense.
Maybe as an experiment i'll buy some decent ones as a one off test, a set of panasonics that are standard parts and a set of crap ones to see what the difference in performance is. I can plot the difference using pink noise and Smaart live which compares the input with the output and plots the result.
I think it's time to look at some data sheets too...
Offline Excavatoree
« Reply #12 on: May 30, 2013, 12:13:06 am »
Rubicons are sweet.  Panasonics add a delicate crispness to the sound, with a hint of a rosy glow.
Offline Bored@Work
« Reply #13 on: May 30, 2013, 04:53:45 am »
Nothing beats the softness and warmth of the sound of a Chemicon going pop :-DD
Offline JuKu
« Reply #14 on: May 30, 2013, 05:24:52 am »
That won't show a difference. If you have an Ap, look at impulse response, distortion vs frequency and IM. You might see someting with a scope and square wave at 50% power and above.
