I am also planning an ATX PSU + DPS3005 + USB PSU.
So this gives me all the ATX rails + a variable, current limited rail.
However, I really want the DPS3005 to provide 15V max.
I thus plan to use -12V and +12V from the ATX PSU to connect to the DPS3005 - but will this give me a problem with the earth - for instance, if I connect the ground of my scope to the 'gnd' output on the DPS3005 then will I get magic smoke?
If so, would it be better to get the buck-boost DPH5005 module instead and feed it 12V to get a 0-50V output?
