Author Topic: Atten oscilloscope firmware????  (Read 68063 times)
Offline Crackn
« Reply #25 on: December 17, 2013, 08:23:18 pm »
Hello, the memory ic arrived today.
I soldered it and I upgraded for 1102CML firmware.
Everything seems to working fine.
Now i need some suggestions on how to test it. To see if the memory is working as expected.
GS
Offline bithead9
Re: Atten oscilloscope firmware????
« Reply #26 on: January 25, 2014, 06:36:15 am »
Firmware updates for ATTEN scopes are here: http://www.atten.com.cn/Download/soft/shiboqi/Update/
I updated my ADS1102CAL with no issues.
UPDATE: 05/03/2014
I have the following firmware from around 3/2014 before ATTEN took down the links.
If anyone needs them please PM or post back here and I can upload them somewhere.
ADS1000CAL Series_Software Version 3.0_V100R003B01D01P31R16.zip
ADS1000CL+ Series_Software Version 3.0_V100R003B01D01P31R16.zip
ADS1000CML_V100R003B01D01P31R16.ZIP
ADS1202CML_.zip
« Last Edit: May 04, 2014, 01:09:59 am by bithead9 »
Offline Crackn
« Reply #27 on: January 29, 2014, 05:08:17 pm »
Siglent 1102CML firmware: 5.01.02.22
http://siglent.com/uploadfiles/en/files/update/SDS1000CML_Update_EN.rar
Tested and working fine with memory mod.
CAUTION: this firmware is for 1102CML or (Memory Modded CAL, CAL+, CNL) scopes. DO NOT install it if you dont have the memory IC installed first.
GS
Offline hifihifi
« Reply #28 on: January 31, 2014, 08:53:57 am »
@Crackn: Why you don't use the ATTEN firmware version CML (=with bigger memory)  ? You can download it here http://www.atten.com.cn/Download/soft/shiboqi/Update/
Do you have 2 or 3 ADC's? like in picture?
http://www.pocketmagic.net/wp-content/uploads/2012/10/atten_1102cal_07.jpg
Maybe this is the difference in ADS1102CAL and the ADS1102CAL+
@Crackn: do you have ADS1102CAL or ADS1102CAL+
« Last Edit: January 31, 2014, 09:57:50 am by hifihifi »
Offline hifihifi
« Reply #29 on: January 31, 2014, 09:30:14 am »
Does anyone know the difference between the ADS1102CAL and the ADS1102CAL+ ?
Offline Crackn
« Reply #30 on: February 01, 2014, 08:27:45 am »
Just because siglent's firmware is version 5 and atten firmwares are version 3. old firmware.
i have the 3 adc version CAL+
see the attached image.
Offline hifihifi
« Reply #31 on: February 01, 2014, 12:31:28 pm »
Damm, I have the ADS1102CAL, I don't have it opened yep, but I suppose there will only 2 ADC's?
I am wondering how the firmware is detecting if there are 2 or 3 ADC's. If not detecting at all, I need to add memory IC and one ADC and maybe more? Will be more tricky.
Offline pickle9000
« Reply #32 on: February 02, 2014, 02:48:20 am »
Offline hifihifi
« Reply #33 on: February 02, 2014, 11:41:52 am »
Thanks !
Great news !  ;D
Looks like ADS1102CAL have 3 ADC's and only new memory chip is needed.
Wondering what's the true difference between ADS1102CAL and ADS1102CAL+ ? If someone know it or find it let me know. Or is it pure marketing?
Offline pickle9000
« Reply #34 on: February 02, 2014, 07:40:30 pm »
I don't know about feature wise but that + board looks to have been simplified, the ram is in a different location and some unpopulated connector footprints are gone.
Offline Crackn
« Reply #35 on: August 23, 2014, 08:06:42 am »
Teledyne LeCroy WaveAce 1012 firmware: 5.01.02.27
http://teledynelecroy.com/support/softwaredownload/download.aspx?did=8107
Tested and working fine with Siglent 1102CML memory mod. (Original Atten ADS-1102CAL+)
CAUTION: this firmware is for WaveAce 1012 (SDS1102CML or Memory Modded CAL+, CNL) scopes. DO NOT install it if you dont have the memory IC installed first and 3 ADCs board.
GS
Offline micro88
« Reply #36 on: September 19, 2014, 06:07:27 am »
I have a 100MHz Atten DSO model ADS1102C which I purchased in 2009 on ebay.
Is there any firmware upgrade available for this model ?
Thanks.
Offline Vratcz
« Reply #37 on: October 07, 2014, 09:31:59 am »
Hello,
I have some troubles with update. My ATTEN 1102CAL oscilloscope died after I updated it by mistake to waveace 100 (I put wrong file to USB stick)
In fact, Oscilloscope stars OK, but there is something like noise on both inputs (looks like the data are taken in the wrong address) -–> the inputs does not works
-When I update back to sieglent1000 (this works in the past!), nothing change – still noise
-when I update back to atten (1102CAL) – scope says “product type does not match” – so impossible to return back to atten
It looks like the LecRoy change some register that are not affected by other firmwares – AD address, or product type (??)
-I add the memory chip on the board with hope that scope starts working – still noise
-when run self-calibration, it take ~10minuts
Otherwise, scope works well :)
Somebody have an idea?
Somebody have atten 1102CML or CL firmware (not sieglent – this does not work)
Thanks
Vrat
Offline hifihifi
« Reply #38 on: October 07, 2014, 10:02:29 am »
kgavionics : talks about changing cfg file
Offline Vratcz
« Reply #39 on: October 09, 2014, 08:25:29 am »
HEllo,
I get the ATTEN CML firmware and the update passed OK, but the problem remain..
I think there is not ATTEN CFG files.. only siglent one
V.M.
Offline scopeuser
« Reply #40 on: November 12, 2014, 10:36:42 pm »
Hello chaps and thanks for the good advice.
I've updated my Atten ADS1102CAL+ using the SDS1000CML firmware update from Siglent. The scope seems to work OK but I don't have the "cfg" file that you talk of and can't find it on the Siglent site?
would one of you be able to give me a copy of it please?
cheers,
Phil
Offline scopeuser
« Reply #41 on: November 13, 2014, 11:46:48 am »
Ignore my previous post, I just found an update package that contained the config file. All done and good!
Offline gunrunnerjohn
« Reply #42 on: November 29, 2014, 04:44:16 pm »
OK, I feel dumb.  I looked and many of the links don't seem to work for firmware, not to mention most seem to be for the ADS1102CAL+.
I have the ADS1102CAL (not plus).  The major issue I see is that the calibration process hangs and I have to turn it off.
I'd like to upgrade the firmware, but I don't want to attempt soldering a new memory chip on, that looks a bit daunting.
Is there a source for the firmware and CFG file for my model?
Offline jagielonka
« Reply #43 on: January 30, 2015, 05:47:20 pm »
Hello,
 I have an ads1102cal atten crashes at startup on screen home siglent. :-//
 Could you send me:
 ADS1202CML_.zip
I will try to unlock it.
 Thanks in advance.
Offline Crackn
« Reply #44 on: February 05, 2015, 05:12:37 am »
UPDATED!
Teledyne LeCroy WaveAce 1012 firmware: 5.01.02.29
List of Changes:
  • Fixed a problem where there was jitter on the output signal
  • Fixed a USB Host Initialization Problem
GS
Offline Micascisto
« Reply #45 on: March 22, 2015, 01:05:41 am »
Hello everyone,
I have a ADS1102CAL+ and tried to upgrade the firmware with the latest Siglent release for the SDS1000CNL.
However, it doesn't recognize the firmware update files and the upgrade stops.
Did you rename those files by chance? I found an old Atten firmware file and it ends in .up instead of .ADS of Siglent firmware files.
Any help or suggestion is appreciated!
Offline Neon
« Reply #46 on: May 21, 2015, 05:11:40 pm »
Hello everyone,
Hi.
I think the ADS1102CAL+ is the SDS1102CML ,just download the correct frimware and install it.
http://www.siglent.com/ENs/gjjrj.aspx?id=15&page=1
There is a new frimware but comes without the .CFG file
we can use the version 13? , I have not tried yet.
SDS1000CML_UpdateCurrent Version: 5.01.02.29 | Published?2015-03-10
Offline Crackn
« Reply #47 on: June 22, 2015, 04:26:34 am »
Hi.
Wrong afirmation. ADS1102CAL+ = SDS1102CNL, Do NOT update it to CML if you don't have the memory mod.
cheers,
Offline Neon
« Reply #48 on: June 22, 2015, 11:04:23 am »
Hi.
cheers,
https://www.eevblog.com/forum/testgear/siglent-technical-support-join-in-eevblog/new/?topicseen#new
Offline jagielonka
« Reply #49 on: July 25, 2015, 08:43:56 am »
Hello
 My ads1102cal atten is bootloop, how do I unlocked?  :-//
Thanks in advance.
