Author Topic: Thermopile circuit?  (Read 804 times)
Offline TeledogTopic starter
Thermopile circuit?
« on: November 17, 2018, 02:15:33 am »
Hi all!
Recently had a gas hot water heater installed - NO electrical hookup to it, whatsoever.
The controller (Honeywell) has a status (pilot) LED that pulses every ~3 seconds or so.
Did a bit of research & don't believe there is any battery in it at all.
I've read that the Honeywell controller uses a "thermopile" to generate ~350mV for the indicator? Not sure of the accuracy.
{edit: from what I can gather, the HOT working voltage should be ~658mV, at minimum 350mV}
I'd LIKE to make the same sort of passive indicator on our ancient boiler  -for a pilot light indicator.
I've looked around & haven't found any schematics out there for building such an indicator circuit..
Is it a proprietary thing?
TIA!  :)
{2nd edit:  nevermind..discovered the LTC3108 ..groovy stuff}
« Last Edit: November 17, 2018, 03:04:20 am by Teledog »
Offline Vtile
  • Ingineer
Re: Thermopile circuit?
« Reply #1 on: November 18, 2018, 06:14:49 pm »
Peltier element can do it. Ie. search for "BioLite".
