Hello everyone! What is the marking, can you tell me The chip is erased, 16 pin.
What does the board do?
I had a search and found this tear down which says, ABOV MC97F1204S 8-bit Microcontroller, which confirms my suspicions.https://goughlui.com/2014/10/02/review-teardown-xiaomi-mi-ndy-02-ad-silver-10400mah-power-bank/
It looks like, there is a program inside the chip, if you don't have the firmware this will be difficult to restore(Похоже, внутри чипа есть программа, если у вас нет прошивки, восстановить будет сложно)
