Electrofinn
I think I can help, but this code totally sucks. Fortunately, my own code mostly totally sucks, so I am pretty good at working backwards to fix things.
You have identified that the look up table named "pattern" is what produces the sequence of 16 frames that you wish to extend to 32. I'm assuming you are correct in identifying this.
Steps.
1. Look at "pattern." It is a table that adds the contents of W to the PCL to determine where to jump and exit from. The contents of W must be between 1 and 16 (or is it 0-15? I'm not sure. In modern PIC I use BRW, in this case it would be 0-15, not 1-16; but I digress) or else the PCL will jump to a point that is outside of the contents of pattern. Hence you must figure out what is loaded into the W register before pattern is called. If you simply add 16 more retlw instructions after the original 16, they will never be executed.
2. Figure out where "pattern" is called. To do this, first locate "pattern" by right clicking on the code and selecting "goto" from the dropdown menu in MPLAB. Then find header "pattern" in the dropdown list.
3. Now you have "pattern" in front of you. Type ".fuckall" after it. Then reassemble. You will get a list of errors where the code is trying to call or goto "pattern." In this case, you will get only one error. But before you click on it, be sure to change "pattern.fuckall" back to "pattern." Then click on the error and it will take you to
where "pattern" is called from. It is called from "feature."
4. In "feature," you will find:
movf counter_hi,W
call pattern
every single time "pattern" is called, the W register is first loaded with the value that is contained in register designated as "counter_hi."
So unless the code is broken, the writer has assured that the value of counter_hi is always something between 1 and 16 (or 0-15?). If it were not, this code would more than likely produce a stack error.
5. Find every instance of "counter_hi" in the code.
5A - locate where the coder defined counter_hi. In this case, it's a short code, and it is easily found at the top. But if it were more complex there are two ways.
A trick I use is to scroll to the very top of the main .asm file and type "counter_hi equ 0"
Reassemble.
You will get an error that says "counter_hi previously defined"
delete the "counter_hi equ 0" you just typed, then click on the error to jump to where the coder has defined "counter_hi"
The good part of this is it will find it no matter what file it was placed in, which it could be one of many .inc files and/or .asm files.
You will find it here:
unused2 equ 14
hold_counter equ 15
counter_hi equ 16
counter_lo equ 17
delay_counter equ 18
So this means that the coder has defined it to be register 0x16 in general memory. Do not change this to 32. This is a fortuitous coincidence, only. This is an address, not a value.
You might have forgotten by now, but the point of locating it was to find out every place it is used in the code. So change the name to produce an error.
write "ASS." in front of counter_hi. So it reads "ASS.counter_hi equ 16"
reassemble. You will find numerous errors of "counter_hi not defined."
Again, be sure to erase the "ASS." before you click on the errors.
Scrolling through the errors one at a time, I get to the eleventh error when I find this code
sequence1
bsf counter_lo,7
incf counter_lo,f
btfss status,zer
retlw 00
incf counter_hi,f
bcf counter_hi,4
movf credit_count,f
btfsc status,zer
retlw 00
bcf mode_byte,7
bcf mode_byte,5
bsf mode_byte,0
retlw 00
If you notice, this code increments counter_hi, but it clears bit 4. Bits go from 0-7. So bits 0-3 are the only things used. Anything that rolls over into bit 4 gets clipped off. This is how the coder is assuring that the contents of counter_hi, and hence the addw PCL instruction in "pattern" do not overflow past 16. In fact, he clips the range to 0-15. 16 is not included, which is why maybe he has redundant value in the spot 15 and 16 in his pattern table. At 16, counter_hi just rolls back to zero.
If you change this 4 to a 5, you will double the range of counter_hi. And your 16 retlw valued you added to the original 16 in "pattern" should now be included in the mix
To be clear, change
bcf counter_hi, 4
to
bcf counter_hi, 5
There may be more things which you must take into account and change, but this will get you started.
