- First, you'll need to correct the schematic for the Vref opamp. I think you meant R5 has to be connected to VCC, not to Vref as it is in the drawing.
- Second, R8 (20k) together with R4+R3 (2k together) will make a DC voltage divider that will make the Out to be centered around Vref/11.
- Third, please also attach the .asc file, so others can download and simulate the same schematic as yours.
