Author Topic: Power bank/UPS with MOSFETs?!  (Read 363 times)
Offline MathCaTopic starter
  • Слава Україні!
« on: February 28, 2023, 03:24:31 am »
Hello,
I bought 8 nice 21700 batteries (4000 mAh 35A) with 4 PD modules (up to 100w each, but more like 60w max for 3/4) to charge a laptop, use a soldering iron, etc. USB C is cool and it made a super fast charger!
Now I want to put everything in one box that will stay connected to mains most of the time. If the electricity goes out for some reason, I want to automatically get power from the batteries instead of the power supply.
I think you should be able to figure it out easily with this:
(unable to get the image here, see the attachment...)
I don't want to use relays, let alone physical switches!
So I guess I have to use MOSFETs? But what type? Alone? I'm totally lost with this...
Thanks!
« Last Edit: February 28, 2023, 03:27:16 am by MathCa »
Все буде Україна!
