Author Topic: Are all FET pins Gate, Drain, Source?  (Read 5497 times)
Offline dog80Topic starter
« on: May 28, 2013, 01:00:09 pm »
I've noticed that in all FETs I've come across the first pin is G, the middle is D and the last is S. Is that some industry standard? Many datasheets do not even bother to identify the pins.
Offline krivx
  • Country: ie
Re: Are all FET pins Gate, Drain, Source?
« Reply #1 on: May 28, 2013, 01:15:52 pm »
In general I wouldn't assume that 3 pin devices are standardised, it nearly always comes back and bites you. I've never seen a FET datasheet that didn't give a pin-out, do you have any examples?
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #2 on: May 28, 2013, 01:20:21 pm »
Assume nothing when it comes to pinouts. I've seen multiple configurations on the simplest of devices.
What datasheet doesn't show a pinout? You've not been looking at some kind of marketing literature have you?
Offline steve30
    • Stephen Coates' Homepage
« Reply #3 on: May 28, 2013, 03:21:07 pm »
I've wondered this recently.
I have a datasheet for an IRF540 which, as far as I can tell, lacks a pinout. However, the device, as far as I can tell, follows the Gate, Drain, Source arrangement.
See attached for the datasheet.
Offline 8086
« Reply #4 on: May 28, 2013, 03:23:22 pm »
The pinout is on page 8.
Offline steve30
« Reply #5 on: May 28, 2013, 03:33:16 pm »
I see it now. They couldn't have made it less obvious. Took me a good five minutes to find it just now  :bullshit:
« Reply #6 on: May 28, 2013, 05:24:50 pm »
Yes, it was a IRF device for me too. The pinout was probably well hidden because I couldn't find it. Why don't they put it clearly on the first page?
Offline krivx
  • Country: ie
« Reply #7 on: May 28, 2013, 06:23:50 pm »
Some manufacturers will put it right on the first page, some won't. Package information is nearly always near the end so that's usually where I look next if it's not on the front page.
Offline dr_p
« Reply #8 on: May 28, 2013, 08:45:45 pm »
Ah.... I don't see it
Offline Psi
« Reply #9 on: May 29, 2013, 01:41:11 am »
2nd to last page, in the Package Outline section.
It's part of the package drawing on the right hand side.
Offline dr_p
« Reply #10 on: May 29, 2013, 07:26:53 am »
Geez... Someone needs to add the pin designations on the first page.
