I made a few tests, as you said.
1. I made a short program, which increased and decreased the firing angle automatically, form 0 to 128.
2. I connected the pot, the lcd and the max6675, and I modified the program and as I rotated the pot, the firing angle increased and if I rotated the pot the firing angle decreased. On the display, all of the values were shown. - so it worked
3. When I introduced the PID algorithm, then it doesn't heated up anymore the soldering iron.
LE: I used this "dim = map(Output, 0, 128, 128, 0);" instead of "dim = Output" , and it seems to work. I don't know if it is correctly, probably I should write " myPID.SetOutputLimits(128, 0);" instead of " myPID.SetOutputLimits(0, 128);" ?
//source: [url]http://www.instructables.com/id/Arduino-controlled-light-dimmer-The-circuit/?lang=pt&ALLSTEPS[/url]
//Arduino controlled light dimmer: The software III
//The code below has been confirmed to work on the Leonardo
AC Light Control
Updated by Robert Twomey
Changed zero-crossing detection to look for RISING edge rather
than falling. (originally it was only chopping the negative half
of the AC wave form).
Also changed the dim_check() to turn on the Triac, leaving it on
until the zero_cross_detect() turn's it off.
Adapted from sketch by Ryan McLaughlin
<a href="[url]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230333861/30[/url]" rel="nofollow"> <a rel="nofollow"> [url]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1...[/url]</a>>
(now here: <a rel="nofollow"> [url]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1...[/url]</a>
#include <TimerOne.h> // Avaiable from <a href="[url]http://www.arduino.cc/playground/Code/Timer1[/url]" rel="nofollow"> <a href="[url]http://www.arduino.cc/playground/Code/Timer1[/url]" rel="nofollow"> [url]http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1...[/url]</a>
#include <PID_v1.h>
#include <max6675.h>
#include <LiquidCrystal.h>
#include <SPI.h>
#include <Wire.h>
#define thermoDO 12
#define thermoCS 10
#define thermoCLK 13
#define potentiometer A0
#define zerocrossing 2
#define relay A1
float realTemperature;
int pottemperature;
LiquidCrystal lcd(3, 4, 5, 6, 8, 9);
byte thermometer[8] = //icon for termometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
byte arrow[8] = //icon for arrow
B11000,
B01100,
B00110,
B00011,
B00011,
B00110,
B01100,
B11000
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
double Setpoint, Input, Output;
double aggKp = 4, aggKi = 0.2, aggKd = 1;
double consKp = 1, consKi = 0.05, consKd = 0.25;
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
volatile int i = 0; // Variable to use as a counter
volatile boolean zero_cross = 0; // Boolean to store a "switch" to tell us if we have crossed zero
int triac = 7; // Output to Opto Triac
int dim = 0; // Dimming level (0-128) 0 = on, 128 = 0ff
int inc = 1; // counting up or down, 1=up, -1=down
int freqStep = 75; // This is the delay-per-brightness step in microseconds.
// For 60 Hz it should be 65
// It is calculated based on the frequency of your voltage supply (50Hz or 60Hz)
// and the number of brightness steps you want.
// Realize that there are 2 zerocrossing per cycle. This means
// zero crossing happens at 120Hz for a 60Hz supply or 100Hz for a 50Hz supply.
// To calculate freqStep divide the length of one full half-wave of the power
// cycle (in microseconds) by the number of brightness steps.
// (120 Hz=8333uS) / 128 brightness steps = 65 uS / brightness step
// (100Hz=10000uS) / 128 steps = 75uS/step
void setup() {
lcd.begin(16, 2);
lcd.createChar(0, thermometer);
lcd.createChar(1, arrow);
lcd.setCursor(0, 0);
lcd.print("STATIE DE LIPIT");
myPID.SetMode(AUTOMATIC);
pinMode(relay, OUTPUT);
pinMode(potentiometer, INPUT);
pinMode(zerocrossing, INPUT_PULLUP);
pinMode(triac, OUTPUT); // Set the Triac pin as output
delay(1200);
lcd.clear();
// digitalWrite(triac, LOW);
digitalWrite(relay, HIGH);
attachInterrupt(digitalPinToInterrupt(2), zero_cross_detect, RISING); // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
Timer1.initialize(freqStep); // Initialize TimerOne library for the freq we need
Timer1.attachInterrupt(dim_check, freqStep);
// Use the TimerOne Library to attach an interrupt
// to the function we use to check to see if it is
// the right time to fire the triac. This function
// will now run every freqStep in microseconds.
void zero_cross_detect() {
zero_cross = true; // set the boolean to true to tell our dimming function that a zero cross has occured
i = 0;
digitalWrite(triac, LOW); // turn off TRIAC (and AC)
// Turn on the TRIAC at the appropriate time
void dim_check() {
if (zero_cross == true) {
if (i >= dim) {
digitalWrite(triac, HIGH); // turn on light
i = 0; // reset time step counter
zero_cross = false; //reset zero cross detection
else {
i++; // increment time step counter
void loop() {
//delay(18);
pottemperature = analogRead(potentiometer);
Setpoint = map(pottemperature, 0, 1023, 150, 400); //pottemperature is volatile
realTemperature = thermocouple.readCelsius();
Input = int(0.779828 * realTemperature - 10.3427); // make temperature an integer
// dim = map(Setpoint, 150, 400, 0, 128);
// if (dim >= 128) dim = 128;
// if (dim <= 0) dim = 0;
if (isnan(realTemperature) || Input >= 432) {
while (true) {
displayErrors();
} else {
updateDisplay();
double gap = abs(Setpoint - Input); //distance away from setpoint
if (gap < 10)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
else
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
delay(300);
void updateDisplay() {
lcd.clear();
lcd.write((byte)0);
lcd.setCursor(2, 0);
lcd.print((int)Setpoint);
lcd.setCursor(6, 0);
lcd.print((char)223); //degree sign
lcd.setCursor(7, 0);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.write((byte)1);
if (Input <= 45) {
lcd.setCursor(2, 1);
lcd.print("Lo");
} else {
lcd.print((int)Input);
lcd.setCursor(6, 1);
lcd.print("[");
lcd.setCursor(7, 1);
lcd.print((int)realTemperature);
lcd.setCursor(10, 1);
lcd.print("]");
lcd.setCursor(12, 1);
lcd.setCursor(13, 1);
lcd.print("C");
void displayErrors() {
digitalWrite(relay, LOW);
lcd.clear();
lcd.write((byte)0);
lcd.setCursor(1, 0);
lcd.write((byte)0);
lcd.setCursor(5, 0);
lcd.print("ERROR!");
lcd.setCursor(14, 0);
lcd.write((byte)0);
lcd.setCursor(15, 0);
lcd.write((byte)0);
delay(300);
In the screenshots, with yellow is the zero crossing signal (pin 2) and with blue is the output (pin 7).
The latest code is above.
Please have a look and tell me what you think ?
