Author Topic: Arduino digital ammeter with a 75mV current shunt?  (Read 21029 times)
Offline ice595Topic starter
« on: August 06, 2014, 02:50:59 am »
Im planning to make a battery capacity meter using an Arduino.
The plan is to use a 10A 75mV current shunt as a current sense resistor then use an opamp to amplify the voltage across the shunt resistor then use the Arduino's onboard ADC to measure the voltage then calculate current using ohm's law.
Here are my calculations:
10A full scale = 75mV across the shunt resistor.
1A = 7.5mV
0.1A = 750uV
If I want my Arduino ammeter to read 5A max then I would need to set the opamp's gain to 133x
5A = 37.5mV
37.5mV * 133 = 4.988V (within the ADC's input range)
But if I want my ammeter to have 0.1A precision, then there will only 750uV across the shunt resistor when theres 0.1A through it.
The questions is, can such opamp circuit be easily made to take 750uV input then amplify by a factor of 133 then feed it to the ADC.
Offline VK5RC
Re: Arduino digital ammeter with a 75mV current shunt?
« Reply #1 on: August 06, 2014, 04:03:34 am »
Suggest google high side current sense amplifier,  several purpose built units for not crazy money,  I used ltc6101 which works well despite a lot of rf around the place.
Offline Rick Law
« Reply #2 on: August 06, 2014, 07:03:27 am »
The plan is to use a 10A 75mV current shunt .....
I had some experience using Arduino (ATMEGA328) ADC.  I did some base line data gathering when I was doing current measurement using shunt.  Bear in mind, the ADC is not exactly linear, at very low voltage (small current), the error is sky high:
You will have very good accuracy > 2V.
at 1V (2A with your 5Volt=10A plan), you would have about 1% error
at 0.5V (1A) your error would shoot up to around 2.5%
at 0.1V (200mA) error would shoot up to around 10%
at 0.05V (100mA) error would be > 25%
and it continues to increase similar to (but not exactly)   "error=constant/V" graph.
I have the "native" (ie:no compensation) error graph here:
https://www.eevblog.com/forum/microcontrollers/atmega328-adc-accuracy-graph/
You will need to do some compensation to get down low.  What I made use about 24x (approx 2A=5V mapping).  With good (software based) compensation, I can get error rate at +- 3 to 5 counts down to high single digit ADC count.  Below ADC=5, error goes explosive.  I did not eliminate the error with compensation.  I have an error graph shape just like the above, but the curve moved toward the left (lesser error until lower).
Good luck and have fun...
Rick
« Last Edit: August 06, 2014, 07:20:44 am by Rick Law »
Offline rs20
« Reply #3 on: August 06, 2014, 07:51:15 am »
Yep, no worries. Refer to Dave's open-sourced uCurrent design. It uses a small shunt resistance and two op-amps, each amplifying by a factor of 10, to give a total gain of 100, which is near enough to what you need. Dave used two separate op-amps because he wanted 300kHz bandwidth, very very good accuracy, etc etc. Depending on how demanding your application is (and if you're using a uC ADC, I hope the answer is "not very"), you can probably get away with a single op-amp just fine. Because the input signals are so small, you'll need to understand input bias currents, input offset voltages, etc -- there's an EEVBlog video about this. Give it a go, show us the design you come up with (and the part(s) you choose), and we'll critique it for you and suggest any improvement or gotchas that you might run into.
This looks suspiciously like a constant error that deceivingly looks like it's exploding at decreasing values only because you're expressing it as a percentage of those decreasing values... I mean, if I measure a 1.6 mV source and the multimeter reports 0.001V, isn't it a bit deceiving to say that it's off by 60%? It's just off by one count. There's a reason that multimeter manufacturers specify accuracies as something along the lines of "DC accuracy: 0.05% + 3 counts". You should probably attempt to do the same (as it sounds like you sort of started to do) and specify the error accordingly; most people who read the results you present above are going to get worried about nothing -- they'll think "oh, no, an error of 25%!?" instead of "OK, an error of 25% on a tiny measured value works out to... a super-tiny error", which is more appropriate in most applications. In the unlikely case you actually need true relative accuracy on a huge dynamic range of signals, you need ranging like a multimeter has.
« Last Edit: August 06, 2014, 07:56:04 am by rs20 »
Offline ovnr
  • Country: no
  • Lurker
« Reply #4 on: August 06, 2014, 08:54:14 am »
Yes, there isn't really a problem using an opamp to boost your signal 133x - just be sure to find one with low input offset voltage, etc.
I'd also strongly suggest using a proper ADC...
Online zapta
« Reply #5 on: August 06, 2014, 08:59:08 am »
Since you want to measure capacity you need to do integration. Some chips will do it for you, that is continuous charge integration. You don't really need an a/d. Check for example ltc2943. You will get better accuracy this way for bursty current.
Offline Richard Head
« Reply #6 on: August 06, 2014, 11:19:51 am »
It's generally best to use a differential amplifier to measure the shunt voltage. Much more convenient.
Offline mij59
« Reply #7 on: August 06, 2014, 11:24:03 am »
You could use a instrumentation amplifier like the INA333.
Offline rs20
« Reply #8 on: August 06, 2014, 02:07:43 pm »
If you want to have a bit of fun and learn things, you can easily configure op-amps to operate in an integrator topology (google "op amp integrator" -- it's just a feedback capacitor instead of a feedback resistor) -- but just using an LTC2943 as suggested is probably quicker.
Do you mean an op-amp in a differential configuration, or some sort of specially designated differential amplifier part? I've heard of parts with differential outputs, but all op amps are sort-of differential input if you want them to be, right?
Note to OP: Many op-amps won't work properly when the input voltages are very close to the rails. For instance, this INA333 is only specified for operation above 0.1V and below supply voltage - 0.1V. You can get around this by shifting the inputs voltages down using a diode drop/resistor dividers, etc. Or use a rail-to-rail opamp, or use LTC2943.
Offline ludzinc
    • My Misadventures In Engineering
« Reply #9 on: August 06, 2014, 02:58:03 pm »
I've recently blogged about my adventures in programmable gain and currrent measurement.
See here:
http://ludzinc.blogspot.com.au/2014/07/microcontrolled-analogue-gain.html
http://ludzinc.blogspot.com.au/2014/07/multi-channel-meter.html
http://ludzinc.blogspot.com.au/2014/08/multi-channel-meter-part-2.html
TL:DR;
Use the MAX4238 as per Dave's uCurrent - he runs that at x100 gain, no worries, x133 should be okay as well.
« Reply #10 on: August 06, 2014, 04:45:05 pm »
wow, I didn't think measuring current would be so difficult.
can't I just use a low drift 1ohm resistor as my current sense resistor? as long the resistance doesn't drift too much with temperature.
Online zapta
« Reply #11 on: August 06, 2014, 04:57:46 pm »
It's not  ;-)
The circuit with the LTC2943 is very simple has small footprint and you can talk to it I2C from the Arduino. It has both A/D for momentary reading and integrator (Coulomb Counter) for accurate and continuous integration. It's high side (good, you get a common ground), only 50mv burden voltage mac scale, and also measures voltage and temperature.  What else do you need? can't be simpler than that ;-)
For shunt you want to use an accurate 'kelvin' resistor. This way you get accuracy off the shelf and can't mess with with PCB soldering variations.  I am using Digikey FC4L64R025FERCT-ND  (0.025 ohm) for 2A range. Scale it down for higher range.
Edit: schematic here  https://github.com/zapta/power-monitors/blob/master/pmon_3v8/eagle/pmon_3v8_schematic.pdf?raw=true
« Last Edit: August 06, 2014, 05:02:03 pm by zapta »
Offline mij59
« Reply #12 on: August 06, 2014, 05:00:50 pm »
What is the voltage range of the source you want to measure ?
A 1 Ohm resistor at 5A will dissipate 25W ! you probably can't afford such a resistor with low tempco .
Offline David Hess
  • DavidH
« Reply #13 on: August 06, 2014, 05:51:31 pm »
It is not difficult but it can be tricky to deal with common mode voltages close to the positive supply rail.  Resistive dividers and difference amplifiers can be used to handle this but they introduce additional common mode errors.
I prefer to use a singled ended level shift with a precision operational amplifier instead of a difference amplifier.  This creates a ground referenced voltage proportional to the current.
http://www.analog.com/library/analogdialogue/archives/44-12/high_side.html
Offline Rick Law
« Reply #14 on: August 06, 2014, 09:40:49 pm »
I am in agreement with that.  Mathematics dictates that a percentage will balloon as the denominator gets smaller and smaller.  Indeed a lot of that graph is illustrating exactly that.
When I was first looking at the data, I attempted to curve fit it.  I looked at the data enough to realize that the count error does increase as it get down closer to zero.  I continue to use that graph as a baseline because it illustrates very clearly how getting down low is getting it more laden with error as well.
The "elbow" dividing the vertical drop and the horizontal "almost linear slow drop".  In my own way of thinking, it defines "the habitable zone" for the ADC verses "the wild country" of the vertical drop.   Now when I make something that depends on the ADC, I do what I can to keep the ADC readings to be inside the "habitable zone".
Offline Rick Law
« Reply #15 on: August 06, 2014, 09:55:06 pm »
Folks here like to recommend the better solutions.   Better solutions will tend to get more complicated than simple ones.  If the application is not demanding, you could do it exactly as your initially layout.  You just have to accept that when you are measuring below 1V, your accuracy will go very very far south.
I actually acquired the ADS1115 for the random / quick&dirty measurements if/when I need something better than the ATMEGA328's native ADC.
« Reply #16 on: August 06, 2014, 10:45:34 pm »
it would be nice if the LTC2943 didn't come in such a pain-in-the-arse pin package.
anyways, what are some popular differential amplifiers that comes in through hole or at least SOIC package?
Online zapta
« Reply #17 on: August 06, 2014, 11:12:15 pm »
You can use a breakout board when breadboarding
https://oshpark.com/shared_projects/HUri2i6R
Or use a schmart board for that package. You can solder it by hand with a fine tip.
Or use an ina169 http://www.adafruit.com/products/1164 , it doesn't have a linear integrator but may be good enough.
At least you have choices ;-)
Offline retrolefty
« Reply #18 on: August 06, 2014, 11:29:34 pm »
I agree with your recommendation. The ADS1115 is a nice general purpose 4 channel (2 diff) with lots of useful configuration options, esp the gain settings. The Adafruit firm has done a good job mounting this to a breakout module and writing a arduino support library making implemention pretty simple.
http://www.adafruit.com/product/1085
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #19 on: August 06, 2014, 11:57:27 pm »
Aren't the Arduino ADC steps 5/1024? That's ~ 4.88 mV. I don't see why it would be any less accurate than that below 1V? Could you please elaborate?
He just needs to amplify x133.33 as he said and a 1023 read at the ADC will mean 5 Amps, or 4.88 mA per count.
Offline Rick Law
« Reply #20 on: August 07, 2014, 01:40:40 am »
If you assume condition is perfect, you would have 4.88mV for every step.   There is no ideal opamp even inside an MCU.  Whatever circuits it uses, it is going to have imperfections.  Random noise in and out side the circuit...Measuring equipment, power supply... they all have their imperfections.
- If I have a 1V source, a 0.01V random noise pulse show up as 1% error.  If I have a 0.1V source, a 0.01V noise pulse show up as 10% error.
- When ADC count is 100, 1 count off is 1%, when ADC count is 10, 1 count off is 10%
- It takes longer time for the ADC to measure 100 count reading than to measure 10 count.  A repeating noise pulse would inject more noise (longer time) at 100 count than at 10 count.
- Count is an integer.  You either get there or you don't.  4.88mV per count means below 4.88mV count is 0.  4mV has a zero count, the 0.88mV error in percentage is infinite.  At 9.76mV (count=2), ADC measuring just a tiny tiny bit low would have count=1, error of 100%
etc etc etc
In short, I don't know exactly where the error comes from, I measured them to be such.  I agree it is rather unsatisfactory, but that's the case with imperfections.
Rick
« Last Edit: August 07, 2014, 01:51:32 am by Rick Law »
Online zapta
« Reply #21 on: August 07, 2014, 02:51:10 am »
The OP wants to measure battery capacity. That means that he will do some long term integration. Random noise with zero average will long affect the results. Also, a typically battery capacity measurement does not get to near zero current or voltage.
Offline Rick Law
« Reply #22 on: August 07, 2014, 03:44:57 am »
True and true...  But just to clarify, I was responding to the later question "why is the error bigger below 1V."
I too thought about if low V really applies here.  He wants to measure current with "0.1A precision" followed by the line "...with 0.1A through it...".  Taking both lines together probably means he wants  0.1A precision going down to a low of 0.1A.
At 5V=10A means he needs to go down to 0.05V (easier for me to think about 50mV instead).
I would consider 50mV being in the low volt arena (10 to 12 ADC count of 1023) - where I would consider "wide country" instead of "habitable zone" of the ADC.
Rick
« Last Edit: August 07, 2014, 03:47:05 am by Rick Law »
Offline rs20
« Reply #23 on: August 07, 2014, 05:38:42 am »
I'm looking at your other thread where you first presented these results. At one point, you show the graph of absolute error, and it was really tiny and not at all blowing up at the left hand side of the graph. So what you should be saying here is "Indeed, a lot of that graph is illustrating exactly that. Furthermore, looking at the data before I made it look insane by dividing by x, I can see that that's 100% of the explanation for the explosion on the left."
:palm: Only because your definition of "the error" is different to everyone else's and inevitably broken at small values... See the confusion and worry you're causing in this thread?
EDIT: Just throwing it out there in case it's the root of the confusion; people often use % to specify ADC accuracy, but that's % of full scale, not % of measured value. Because it's impossible to build an ADC that's accurate to even 40% for all measured values, quantization error forbids it.
« Last Edit: August 07, 2014, 05:45:06 am by rs20 »
Offline Rick Law
« Reply #24 on: August 07, 2014, 07:11:19 am »
I do see your point.  I use percent as percent of reading as typically the reading is end result, and likely displayed somewhere for use; whereas FS may not be remembered (if different dividers/multipliers deployed via a selection switch.)  So while %FS is more technically definable, %reading is more "user-friendly".
I did the graph so naturally it was clear to me, but I can see how others could get confused.
It is also clear from some responses that some doesn't expect absolute error would increase and expected 1023 bit precision to the last count.  Error does "explode" from the perspective of the user who merely read the final voltage/current reading.  The noise that was nothing before suddenly becomes deadly.  When you are down to single digit/low double digit ADC counts, the reading isn't so meaningful anymore.  So I think while it may be confusing, it served some purpose to raise the awareness for those who hasn't attacked this problem before.
Rick
« Last Edit: August 07, 2014, 07:38:25 am by Rick Law »
