Don't use that bulb in the open. If you want to experiment with fluorescence get a disco blacklight tube or UV LED torch. Those germicide lamps produce very short wave UV and will injure your eyes and give you bad sunburn as well as produce ozone.
365nm is UVA and that should strongly excite fluorescent materials, it's also safe to look at.
Be careful - these can cause eye and skin damage.
