I just briefly checked continuity from the AC inlet to the inputs on the Power supply. The meter beeped, but sometimes it took a bit of moving the probes around. And the solder joints are pretty cold-looking. Is it worth it for me to try to reflow the solder on those joints, or is continuity usually a bit fussy to test for on solder joints?
