Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Repairing a DVD player
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Repairing a DVD player (Read 1507 times)
R4v3n5
Newbie
Country:
on:
July 28, 2017, 07:51:50 am »
Hello
My cousin gave me his DVD player to see if I can repair it.
Upon opening it I could see that the reason was probably the really obviousely leaked cap.
Now should I also change all of the other caps, as my logic is telling me that they will probably soon follow or should I just measure them and see.
Edit: typos
Last Edit: July 28, 2017, 01:13:36 pm by R4v3n5
Logged
Gyro
Super Contributor
Country:
Re: Repairing a DVD playee
Reply #1 on:
July 28, 2017, 08:49:31 am »
Hello, Welcome to the forum
Wholesale replacement of all the caps is probably going to be a false economy. In a switchmode power supply it it only the stressed ones on the output side that tend to fail. Look for bulging tops and leakage on the other ones and replace any likely suspects. The high voltage reservoir cap on the primary side almost never suffers.
I don't know your level of experience but you should be very careful working on mains powered equipment - and mains powered SMPSs in general. Be aware that the High voltage capacitor can sometimes retain charge that can give you a nasty belt. Check it with a meter before woring on the supply. Check carefully for solder splashes etc. before to re-fit it and apply mains.
Edit: Snap!
Logged
Best Regards, Chris
R4v3n5
Newbie
Country:
Reply #2 on:
July 28, 2017, 10:36:48 am »
I forgot to mention that I meant only the caps on the psu.
For measuring I have a chinese component tester which also shows ESR values.
For my experience I am studying electrical engineering and I always make sure the caps are discharged before doing anything.
I will take some photos once I get home from work.
Logged
NivagSwerdna
Super Contributor
Country:
Reply #3 on:
July 28, 2017, 10:42:32 am »
Quite a while back I fixed mine...
I seem to remember that I had to replace a couple to get it to work... the most obvious candidate didn't actually solve the problem. I only replaced a couple though and those had obvious bulging leakages.
Logged
R4v3n5
Newbie
Country:
Re: Repairing a DVD player
Reply #4 on:
July 28, 2017, 03:21:36 pm »
As promised here are the photos.
https://app.box.com/s/n1sk5r5zlbh75zl4u0jaij7tzr4le9is
If you would like any more photos just tell me.
Logged
senso
Frequent Contributor
Country:
Reply #5 on:
July 28, 2017, 03:23:45 pm »
Replace them all, one is already burst open.
Get something semi decent if you can, try to use TME, their shipping is very decent and its "near" you, so 2-3 days or less of waiting time.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
