The nominal transformer secondary voltages are approximate.
A difference of the order you are seeing is not uncommon for a transformer which is not supplying current to a circuit.
Another reason the secondary voltage may be a bit high (even when loaded), is if the ac Mains supply in your area is high.
For these reasons, I would suggest your transformer is OK.
