Author Topic: Analyzing Response time of Comparator  (Read 682 times)
Offline kankanasTopic starter
  • Country: in
« on: July 07, 2020, 06:52:29 am »
I am trying to find the response time of the LM311 Comparator. In the datasheet, the test condition is mentioned as "a 100-mV input step with 5-mV overdrive".
I am a bit confused about the input of the ckt to be taken. I am attaching the schematic which I can think of now.
I visited various sources online, but the inputs to be taken are not clear.
Please correct me if my understanding is wrong.
  • Country: in
Re: Analyzing Response time of Comparator
« Reply #1 on: July 07, 2020, 06:54:39 am »
Below attached images..
Offline mikerj
« Reply #2 on: July 07, 2020, 08:09:00 am »
Set V5 to 95mv.  This gives you a 100mV input swing with 5mV (i.e. 100-95) overdrive.  Also it's not good practice to set rise and fall time to zero, it's an unrealistic value that can sometimes cause convergence problems in SPICE.
  • Country: in
« Reply #3 on: July 07, 2020, 09:10:46 am »
Is this ok?
Offline mikerj
« Reply #4 on: July 08, 2020, 11:26:25 am »
Yes that looks ok.
The following users thanked this post: kankanas
