Author Topic: What functions can be implemented in a single CLB block of XC4000?  (Read 242 times)
Offline r20de20Topic starter
Hi there!
School stuff. I try to learn FPGA and know few things, but it seems I don't quite understand them.
There is this task:
"Can the following logic functions be implemented in a single CLB block of an XC4000 device?"
While I know the answers:
These are possible:
any 5-variable function
any 4-variable function + a specified 5-variable function
a specified 9-variable function
any 4-variable function + a specified 6-variable function
2x any 4-variable function + any 3-variable function
These are not:
3x any 4-variable function
4x any 2-variable function
a specified 10-variable function
any 6-variable function
... I'm not sure of some of them. As per my knowledge, one CLB block of XC4000 consists of 3 LUTs, a mutliplexer and other parts like flip flops, carry. Each LUT has 4 inputs and 1 output.
So it is pretty obvious function with 6 variables wouldn't work, because it has 2^6 = 64 different cases, while LUTs support only 3 * 2^4 = 48 cases. But why is "3x any 4-variable function" impossible to implement? For me it is exactly matching the size of inputs we have available, so it is clear I lack knowledge in this topic. I've tried to research it online and used GPT, but I haven't found any information related to this question.
I kindly ask you for explanation. Thank you in advance for any tips/rules, which would help me in the future.
Offline CaptDon
  • Country: is
Re: What functions can be implemented in a single CLB block of XC4000?
« Reply #1 on: June 24, 2024, 07:20:12 pm »
Better to move this to the FPGA forum.
Offline up8051
« Reply #2 on: June 24, 2024, 10:14:39 pm »
http://xilinx.pe.kr/_xilinx/html/ref/fpga4000.html
Two LUTs are 4 inputs
One LUT is 3 inputs
The following users thanked this post: r20de20
