Author Topic: One short pulse switch needed  (Read 654 times)
Offline charles713Topic starter
« on: September 02, 2019, 01:30:40 pm »
Hello Everyone, I have a 12V motion detection switch, a 12V power supply and 12V buzzer that I want to buzz shortly (0.5 to 1.0s) once the motion is detected. What should I look for and use as one short pulse switch?,relay? I have no idea about this stuff. I am familiar with basics only. Will appreciate your advice. Thanks!
Offline GerryR
Re: One short pulse switch needed
« Reply #1 on: September 02, 2019, 08:40:22 pm »
You can buy a programmable Timing Relay, and set it up as a one-shot for the time required.  Schneider Electric / Magnecraft makes one, 822TD-10H/UNI from Newark or Allied Electronics will do what you want done.  You can probably download the spec sheet to see how it operates.
Still learning; good judgment comes from experience, which comes from bad judgment!!
Online Zero999
  • 0999
« Reply #2 on: September 02, 2019, 09:08:12 pm »
The classic is a monostable, typically a 555 timer.
https://www.electronics-tutorials.ws/waveforms/555_timer.html
The following users thanked this post: charles713
« Reply #3 on: September 03, 2019, 09:35:14 am »
Thank you, a "timing relay" was what I was looking for. There are ready to connect inexpensive ones on eBay or Aliexpress, so I am good now.
