Okay so I finally* managed to build up a (sort of) prototype on breadboard and it seems to work reasonably well. I've been able to draw 3A at 30V from my Manson NRP-3630 PSU (36V/3A),
however I am a bit puzzled by the discrepancy of the 'set' voltage and the current actually drawn from the PSU. For example - at the moment the set voltage is set to roughly 0.33V. If I measure the voltage across my 0.100R shunt resistor, I get the same voltage.Nevermind, looks like I have some heavy losses on my bread board that probably explain the discrepancy.
Measuring between the GND near the 0.100R shunt and my main GND "node" (a few centimeters away) shows a 90mV drop ...
Guess it's perf board time again ...
(* - Damn you Borderlands 2 and your addictive gameplay!
