Author Topic: Difference between RF detector and power sensor  (Read 2715 times)
Offline pigrewTopic starter
« on: April 16, 2017, 07:59:07 pm »
What's the difference between a RF diode detector and a power sensor?
Is it mostly just that power sensors are well calibrated, temperature compensated, and have log amplifiers?
Thanks,
Nathan
Offline PA0PBZ
Re: Difference between RF detector and power sensor
« Reply #1 on: April 16, 2017, 08:13:09 pm »
I think you answered your own question: An RF detector can indicate the presence of RF, and will give you a more/less indication. A power sensor will do the same but will have a calibrated output in dBm/mV/whatever.
Offline K5HJ
« Reply #2 on: April 19, 2017, 02:35:22 am »
Typically, the diode detector measures voltage which can be used to calculate power.
The power sensor measures thermal energy and gives a true representation of power.
Randy
Online rfeecs
« Reply #3 on: April 19, 2017, 04:54:37 pm »
Randy
Since most power sensors have a 50 ohm input impedance, if you measure the voltage then you know the power.
Many power sensors are in fact diode detectors.  When operated in the square-law region, the detector's output voltage is proportional to the power.
If you look at Keysight's power sensors, they have two types:  most are diode detectors;  the other is thermistor or thermocouple based.  The thermistor power sensors use a thermistor to measure power by measuring the temperature rise with a thermistor.  Similarly with thermocouple sensors.
Lately, with cell phones and LTE, there is a lot of interest in measuring signals with multiple carriers that have a high peak to average power ratio.  So you get two different types of power measurement:  peak power and average power.  Thermistor sensors only measure average power.  Again if you look at Keysight's sensors, they have some that can measure both peak and average power.  This requires diode sensors.
Here's Keysight's power meters and sensors for reference:
http://www.keysight.com/en/pc-1000000475%3Aepsg%3Apgr/power-meters-power-sensors?cc=US&lc=eng
« Last Edit: April 19, 2017, 05:02:25 pm by rfeecs »
