Note that searching for meters with hFE measurements will give you the lower quality meters with many features. The hFE sockets are rarely isolated very well, if you're measuring dangerous voltage, this voltage is also likely on the transistor socket. Few, if any, high-quality meters are able to measure hFE. Since the DC current gain is a function of collector current and temperature, it's not a very useful measurements. About the only thing it's good in my opinion for is figuring out the polarity, pin-out and if it's shorted. Two or three diode measurements will tell you the same, however, and will work with a much wider range of devices and packages (eg. TO-220, or SOT-23).
