Hello,
I am unable to build a stable window comparator that accepts input voltage from 21 Volts DC till 30 Volts DC.
SO i think if the HYS was at 1V then it would fix the situation better.
When i add a capacitor 1uF or greater at the drain pin of "M2" , things get crazier .
Label "main_vin" without "R9":
I would like to build a window comparator similar to this IC
http://cds.linear.com/docs/en/datasheet/4418f.pdfDo you think it is safe to use a zener diode 6.2v as a regaulator from 24v supply or 30 vdc or greater!!! ?
I am looking for a fast start regualtor that is why i thought of using a zener diode . Your recommendation is appreciated.
By the way , resistor "R_MON1" or "R_MON2" shows that each comparator is dissipating continuous 16 mA which is bad for a battery .
Is there a fast comparator with low power dissipation ?
I appreciate your help.
