Author Topic: Need help with SEPIC converter  (Read 914 times)
Offline MenxiuTopic starter
  • Country: bn
« on: February 03, 2018, 04:34:43 pm »
I'm currently building a SEPIC dc-dc converter. I have laid out the components on LTSpice and I'm having trouble getting the results i want.
Requirements :
5V input
1.245V - 12V output
Also, how do i manage the current? As i have a prototype built, my LT1370 chip seems to be getting quite hot.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Need help with SEPIC converter
« Reply #1 on: February 04, 2018, 02:08:39 am »
Grounding /SHDN would seem to be a non-starter...
Those capacitors in series will generate a singular matrix error.  Use a single one, or set RSHUNT = 1e8 or less, or put a resistor across one or both capacitors.
Can also add a coupling statement, "K1 L1 L2 0.98" and use a coupled inductor part.
Seven Transistor Labs, LLC
The following users thanked this post: Menxiu
  • Country: bn
« Reply #2 on: February 05, 2018, 10:43:49 am »
Thanks for the reply. I've managed to get it the SPICE model working by removing the ground to the S/S pin.
In my prototype however, i'm not getting any output at all. My inductor L1(Connected to Vin and Vsw) seems to be getting 18V across it. Any idea what could be the issue?
