Author Topic: USA (110V) Electrical Question: Can't find LED light dimmer with GFCI outlet?  (Read 5723 times)
Offline petrezaTopic starter
I have spent more than an hour searching for such a thing and this is the only place I know to ask. It seems to be rarer than the teeth of a unicorn riding hen.
Basically I need this:
http://www.homedepot.com/p/Leviton-15-Amp-125-Volt-Combo-Self-Test-Tamper-Resistant-GFCI-Outlet-and-Switch-White-GFSW1-0KW/206000203
but with a little dimmer slider like this:
http://www.homedepot.com/p/Lutron-Toggler-600-Watt-Single-Pole-3-Way-Eco-Dimmer-White-TG-603PGH-WH/100663449
that is LED compatible.
Any help would be greatly appreciated as I am at my wits end.
Thanks!
Offline Monkeh
I don't know that they would make such a thing.
Can you not just get a dimmer and mount it next to your outlet?
It's for the bathroom. There is only one switch hole in the wall and modifications are impossible. So the only choice is to find a replacement.
Thanks!
Offline P90
Hole?  Lol.
Just install a double device remodel box. If there's no room between stud location for a double box, install two single boxes vertically. Not ideal, but works, and allowes for the installation of two standard devices, switch, dimmer, recep., etc...
Offline Monkeh
I am imagining he doesn't want to try and cut a tile on the wall.
The wall is made of some kind of cement mix with a metal mesh for support half way through the wall - its not hollow. Also I am renting this place and if I did what you suggest the landlord will evict me.
Thanks though! But replacing the switch is the only way.
Offline P90
You'll have to go without a dimmer. They can't fit a receptacle and all the dimmer electronics plus heatsink into a single combination device.
Offline P90
One other thought... since you're renting, you shouldn't be messing with anything electrical for liability reasons. Just be careful. ;)
Offline radar_macgyver
Offline P90
Use the GFCI+switch you found, plus an in-line dimmer: http://www.truevalue.com/thumbnail/Electrical-Lighting/Switches-Outlets/Dimmer-Switches-In-Line-Cords/pc/4/c/58/497.uts
Ummmm, I'm guessing he's trying to control some canlight or a hardwired light fixture...
Yes, the dimming should be for the hardwired light fixture that is connected to the flip switch. The outlet is for general 110V use.
Offline P90
If it's a standard light socket, perhaps buy an LED bulb with remote control
Just a thought
Offline grifftech
    • youtube channel
run a long cord for the plug :D
Offline Back2Volts
Would it be such a nuisance to run the light at 100% with no dimmer ?    That is what I have in my newly remodeled master bathroom.
Offline Doofenshmirtz
Make the problem easier?  Move the GFCI breaker to an outlet upstream in the circuit.  Then you only need to source a dimmer/outlet.
I'd hesitate to do this as a renter; as a landlord, I wouldn't be too happy if a renter did it without asking, but I'd be cooperative if they checked first and the work was done to code (i.e., a licensed electrician, at their expense).
