Author Topic: propagation delay question  (Read 3567 times)
Offline MrAl
Re: propagation delay question
« Reply #50 on: August 03, 2023, 09:41:49 am »
Funny u should say "100%"
If you dont think im 100%,    make sure that u are,  or your in trouble too.
Yeah you need to pay attention to your replies or you will not be taken seriously anymore.
Online MK14
« Reply #51 on: August 03, 2023, 09:42:41 am »
By seeing someone, who can help, medically, if necessary.  It can make you feel a lot better, and improve your quality of life.
Then, if you still want to do hobby projects.  You will be more able to do them, in a consistent, reliable, and constructive way.  Ending up making useful things, hopefully.
Offline robowaffeTopic starter
  • Country: bs
« Reply #52 on: August 03, 2023, 09:54:08 am »
What AI have you actually got going yet?  Calling yourself MR AI?  You must be quite good at it,  or is it just a dream for your future?
Offline tggzzz
« Reply #53 on: August 03, 2023, 09:55:30 am »
Robowaffe: to avoid confusion and doubt, will you please confirm or deny that is you.
Thanks.
Offline Zero999
  • 0999
« Reply #54 on: August 03, 2023, 05:50:36 pm »
Thanks.
I'm now pretty sure he's krayvonk. It was a few years ago, so I could be misremembering.
The following users thanked this post: MK14
Online MK14
« Reply #55 on: August 04, 2023, 07:04:59 am »
I think they ran a number of accounts, mostly banned.  Apart from the recent one(s), such as the OP.
E.g. Capernicus
https://www.eevblog.com/forum/profile/?area=showposts;sa=topics;u=762538
They also, seem to be disrupting other thread(s) (ones they didn't start), with apparently nonsensical answers.
if u just want v2-v1,  you can just do a raw power subtract.
It reduces the amps and the volts at the same time.
U dont need an opamp for a gain of 1.
I intentionally kept out of that thread, as I didn't want to disrupt it, and would have expected a bad response from robowaffe, if I tried to correct them.
There seems to be talk of a large number of reports on robowaffe, yet I can't see much action, on an apparently disruptive, many times permanently banned, 'member'.  So I can't see much point, in making reports about them, via the 'report to moderator' feature.
The disruption they seem to cause, may NOT be their fault (i.e. intentional).  But if someone is beginning to be a bit ill (or worse) or taking funny substances, action may still need to be taken.
« Last Edit: August 04, 2023, 07:11:58 am by MK14 »
Offline MrAl
« Reply #56 on: August 04, 2023, 08:43:04 am »
Hello,
What has this got to do with propagation delay?
You seriously don't know how to take advice even though you appear to have very little knowledge in these subjects at hand.  That's a bad combination and unless you can correct that you won't be able to progress in this field or any related field.  It's your choice.
As a side note, you also don't seem to know how computer fonts work or else you would not have gotten the member name wrong:
l vs I.
Look it up or something, or maybe need glasses?
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #57 on: August 04, 2023, 10:09:05 am »
Don't worry, he won't be answering anything anymore until he re-registers.
The following users thanked this post: Zero999, MrAl, MK14, JustMeHere, golden_labels
