Author Topic: A rose by any other name would smell as sweet... But this?  (Read 2829 times)
Offline Rick LawTopic starter
« on: November 17, 2013, 11:07:57 pm »
Greetings, If you don't mind firing a few brain neurons for me, I can use your help.
What do you call this?  (photo attached)
This is for the alligator clip to clip on-to.  I've searched for hook, eye, clip pin, clip loop, clip mount, clippee...  No luck.  Just can't find the darn thing to buy without knowing the right name.
Thanks
Rick
Offline Skimask
Re: A rose by any other name would smell as sweet... But this?
« Reply #1 on: November 17, 2013, 11:11:27 pm »
Looks like a .2" jumper, something that a guy might clip after a one-time programming.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline David_AVD
« Reply #2 on: November 17, 2013, 11:15:48 pm »
I'd try "test point".
Offline Psi
« Reply #3 on: November 17, 2013, 11:30:51 pm »
I don't think they are intended for test points.
You see them on PC motherboards quite a lot to hold the chipset heatsink on.
There's a metal spring hook which attaches to two of these on opposite corners
Offline Rory
« Reply #4 on: November 17, 2013, 11:47:27 pm »
Found it. It is a BGA solder anchor. Here's a link to one. Search term 'bga solder anchor' in your favorite search engine comes up with lots of hits.
http://www.aavid.com/products/bga/solder-anchors
« Last Edit: November 17, 2013, 11:49:02 pm by Rory »
« Reply #5 on: November 18, 2013, 05:31:39 am »
Thanks, guys!  The solder-anchor I had was indeed removed from an old PC mother board long time ago.    I've seen it in an electronic video some where used for an alligator clip.  I was going to get a few to use for alligator clip connector.
I was pulling my hair out trying to find it!  Heat sink was simply not in my mind!  I kept searching under variation of gator-clips.
The solder-anchor does look like it works well for a gator clip.  I didn't know there is such thing call "test point (connector)".  Looking at images of these "test point connectors" found on google, some look like just a bend wire.  May be I should just bend a wire into a U shape solder that in and call it a day.
Offline notsob
« Reply #6 on: November 18, 2013, 05:35:23 am »
Test Connectors - this may help to give you an idea on what is available
http://www.toby.co.uk/content/catalogue/series.aspx?id=6&Category=31
