Author Topic: Bass (low frequency) sound detection?  (Read 2608 times)
Offline jorencaTopic starter
  • Country: bg
« on: August 09, 2016, 08:43:19 pm »
Hi forum,
I'm trying to build a simple LED bracelet that would light up when (very loud) ambient music has
lots of bass in it (for example, when the beat 'drops').
However, I encountered the problem where the microphones in my junk bin are all 'telephone' grade ones -
that meaning with a small bandwidth, most likely outside the range of 20-200Hz.
I started wondering if I could use some reed switch to register the sound, but it seems reed switches
have a resonant frequency of about 8kHz.
Can you propose a sensor to be used, seeking maximum simplicity and low energy consumption?
(you may have guessed that I'm building a glowing party bracelet and the overall size is the main limiting factor)
Thanks!
Offline scanlime
Re: Bass (low frequency) sound detection?
« Reply #1 on: August 09, 2016, 09:34:58 pm »
Maybe a place to start would be designing a mechanical circuit that has a resonance peak near the range you're interested in? You'll want something with a large surface area that can be sensitive to bass vibrations, without being affected by body motion.
If you can create a mechanical surface that's sensitive enough to the bass, you may be able to pick up those vibrations with piezo.
Offline Zero999
  • 0999
« Reply #2 on: August 09, 2016, 09:51:02 pm »
Use an electrect microphone capsule which should be fairly sensitive to bass.
Offline Brumby
« Reply #3 on: August 09, 2016, 11:11:59 pm »
... and a low pass filter ... etc.
Offline Audioguru
« Reply #4 on: August 10, 2016, 02:22:20 am »
Here is the frequency response of an ordinary electret mic. It goes lower than 20Hz but the graph stops at 25Hz. A cheap one measures a little different at high frequencies.
