Author Topic: A newbie exploring MCU's  (Read 18236 times)
Offline stev.dk
Re: A newbie exploring MCU's
« Reply #25 on: June 02, 2013, 09:27:19 pm »
Crank it up till' everybody's ears are bleeding, then back off just a notch.
Offline C
« Reply #26 on: June 02, 2013, 09:45:43 pm »
just starting you might want to think on what kind of things you create.
Coming from the software side may change things also. You may have a lot easer time dealing with software and more problems dealing with limited hardware.
This may be wrong and is in some cases, but from my looking.
AVR is a line of chips that add instructions as mpu power increases.
PIC  is a family of chips so you have a lot of changes both in instructions sets and built in hardware when you shift lines(pic16, pic18, picXX) with in the family.
With an ARM chip you may have a large number of the same type of interface and a lot of different types at a low cost. If you can find a chip the same in AVR, PIC it will most times cost more.
For some projects, if you look at total Hardware costs it could be cheaper to start with one of the many ARM chips. With other MPU's you may be adding chips to do a job while with ARM what you need is in the chip.
Very few ARM chips are in dip packages, so with ARM it would be better forget DIP packages. ARM chips also can have a lot of pins.
On the very low end you have a mpu being something like smart logic. If an ARM chip can do the needed task, you still have more pins and chip cost does not go as low as AVR, PIC or MSP430.
If your project is connecting to a PC then your best choice I think would be a USB connection. You could use a MPU with out a USB interface and add a chip to get a USB serial port or a USB parallel port or you could use a MPU with USB interface built in and have the option for both and more. With an internal USB interface you have more options but more to do in software to get it to work. With internal USB you can have higher speeds an move to more packet based communications. As the need for speed increases the deck shifts more to a ARM based choice and at some point is the better choice.
If you want a graphics based screen for display, the deck is shifting to ARM.
If you want faster floating point or bigger integers the deck is shifting to ARM.
The reverse is also true, for some tasks/projects the deck is stacked against the ARM.
So ARM gives a huge range of options in cpu hardware chips and has more computing power. This means a bigger learning curve up front and I see less ARM specific examples to work from. If you want easy plug together hardware this is not it and you would probably do better with arduino, but that is not a good statement as there are now ARM based boards for arduino platform that limit some capabilities of the ARM chip.
You could build a clock with any of them. If you want to add graphics or sound the deck starts shifting to ARM.
For an expensive ARM start
STM32 discover boards are the lowest and include a programmer & debugger. You could use the programmer & debugger for some other projects using ST's line of STM32 ARM chips (<$16). Most of the STM32 discovery boards have some added chips to play with to get you started.
NXP's lpcxpresso boards NXP site states "The platform is comprised of a simplified Eclipse-based IDE and low-cost target boards which include an attached JTAG debugger". NXP's mbed is the high end
I would suggest If you are leaning to higher end projects ARM might be good in long run, but may have a higher learning curve at the start.
Offline smashIt
« Reply #27 on: June 02, 2013, 09:49:24 pm »
my 3 reasons why I went PIC:
- PICkit
- 32bit PICs are available in dip-packages
- free samples, even for hobbyists  8)
Take a look at ATmega8 datasheet, page 302. You can see most instructions take 1 or 2 cycles, very few take up to 3, and only 2 branch instruction go up to 4. Now let's have a look at PIC16F1786 datasheet, page 379. Most instructions take 1 instruction cycle (4 clock cycles), all the control intructions (branch would be Atmel's equivalent) take 2 cycles (8 clock cyc.). Now compare the two.
So, top PICs go up to 32MHz (8MIPS), top AVRs go to 20MHz(20MIPS). AVR still wins. :P
top 8 bit pics go up to 64mhz (pic18 series)
according to the rest of your data (4 cycles / instruction for pic, and ~1,5 cycles for atmel) that would put pics at ~16MIPS and atmega at ~ 14MIPS
sounds like a tie to me
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #28 on: June 02, 2013, 10:19:21 pm »
I'll throw a wrench into the mix and recommend PSoC from Cypress, especially the PSoC 3, 4 and 5.
It's not really possible to define the "best" chip unless you have also defined the application.  If it's just to learn, then learning ARM would probably be the most useful in one's career, IMO.  If it's just to have fun, Cypress has a ton of dev kits and sample kits that show off a lot of cool functionality with PSoC.  The built-in peripherals make things like USB and SPI easy, and interfacing with LCD, LED and I2C very easy as well.  And one of the biggest benefits is that when you get more advanced, you can write your own Verilog - so you're getting into FPGA land all in a very easy to use very simple chip and toolchain.
We used to use all Atmel in our designs, now we use all PSoC.  Atmel chips are not bad, but I don't like the company.  Their support sucks and IMO their treatment of the small guys suck too.  And honestly, there are way more d-bags in the Atmel community who will talk your ear off about how the AVR chips are better than everything else.  It's like listening to Apple fanbois sometimes!
It's not always the most popular person who gets the job done.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #29 on: June 02, 2013, 10:54:10 pm »
Weeeeeell... It's the Mega family that goes to 20MHz max, the XMega family (also 8-bit) goes up to 32MHz. :)
« Last Edit: June 02, 2013, 10:56:16 pm by Dave »
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline smashIt
« Reply #30 on: June 03, 2013, 12:02:29 am »
weeeeeell... that would result in approximately 16 vs 20 MIPS
still far away from your x4 performance-difference
BUT!  >:D
atmel is advertising them for 16bit tasks
do you realy want to compare them to a dsPIC or PIC24?
but the whole argument is moot anyways
Offline mark5009
« Reply #31 on: June 03, 2013, 04:43:09 am »
Casper,
Originally, you said "Could a kind soul perhaps guide me in some direction such as best starter kit and/or resources which could help a noob like me get a feel for this new MCU world? I don't really have any specific requirements, apart from cheap/small/easy and A/D would be nice too."
Get onto the Microchip website and order a Pickit2.  Then send them an email and ask for a few chips that you like the look of (samples).  This will set you back $50 or so.  It includes a C compiler, etc..
If you prefer open-source and something other than C, there is JAL which runs under windows and Linux.  You can find more info about it here
  http://justanotherlanguage.org/
 .. mark.
Offline MacAttak
« Reply #32 on: June 03, 2013, 04:50:37 am »
Arguing over which is better is pointless unless you folks are just looking to blow off some steam?
Just look at the toolchains and make a decision based on your own preferences about IDE platform and features. If you like Windows and the Visual Studio environment, then maybe AVR is the right path (Atmel Studio runs inside the Visual Studio 2010 shell). If you have reason to dislike that, then perhaps PIC is a better choice. Or as someone else mentioned, you could set up a custom toolchain using gcc and avrdude to get an AVR environment running minus the IDE features.
Personally, I like the AVR tools and Atmel Studio. I have a JTAGICE3 and an assortment of AVR's - from tiny13's up to mega's. The IDE works well, and the DebugWire functionality has come in handy a few times.
I'm sure PIC are great devices too. But I hate Basic, and have no desire to use ASM unless absolutely necessary. And since I'm already comfortable with AVR, I see no need to worry about PIC for the time being.
But you might have entirely different preferences.
Also, in the tear-downs here (as well as my own limited repair work), it seems like Atmel parts show up far more often than PIC. I'm not sure what that means, if anything.
Offline madires
  • A qualified hobbyist ;)
« Reply #33 on: June 03, 2013, 12:42:09 pm »
You can also have an IDE with your custom tool chain. Eclipse with the AVR plugin runs fine on Windows and Linux PCs. Eclipse also supports tons of other stuff (even PICs), so you got one IDE for several targets. I like consoles and simply use make :-)
Offline casper.bangTopic starter
  • Pro SE, amateur EE.
    • BangBits
« Reply #34 on: June 03, 2013, 01:12:17 pm »
Casper,t
I talked to some EE's at work (I'm a SE not an EE) and I was offered all kinds of (to me) overkill dev boards. Thankfully they also had a Microchip Pickit1 with a 12F675 and mini USB connection, which looks fine for me to try. I was very close to ordering AVR AVRISP mkII and some 8-bit ATtiny MCU's and I might still after I check out the PIC stuff. It's not really about the $30 - $60 investment cost (you reach a point in life where you value time more than your money), but free and available is hard to beat! ;) Thanks for the feedback guys, I definitely learned a lot from the comments.
Offline C
« Reply #35 on: June 03, 2013, 02:54:43 pm »
casper,
with the great offer from the guys at work, you might have missed something.
I would say that a lot of the " overkill dev boards"  might have been created to save the EE time to test out an idea. I would expect that some of the  "overkill dev boards" as you call them were created for some area specific area of mpu use, while some might be more general an have some hardware for a lot of areas.
The Idea is build or use an example that came with the board. Then slowly replacing/modifing hardware/software parts of the " overkill dev boards" with your own circuits until you are no longer  using the " overkill dev boards" hardware.  Instead of a software & hardware problem at the same time, you fix a hardware problem then update and improve the software.
If you are going with PIC you might want to look see if any are based on PIC.
As most also come with schematic(s) and part lists, you also have hardware design that works with a specific chip. Some very good reference material in that offer.
C
    • BangBits
« Reply #36 on: June 03, 2013, 04:13:04 pm »
I hear what you are saying. The thing is, I'm interested in miniaturizing rudimentary legacy designs revolving around such components as a 555 timer, 339 comparator, ADC's, discrete logic gates and the like. I really have no interest in developing full blown miniature computers, which these development boards really are about. For that kind of performance (in fact, much higher performance than any comparable dev board I have seen), I'm using my cheap 50$ Android stick with a USB-Serial adaptor and GPIO adaptor, since it allows me to use proper high-level GC'ed languages like Java and Mono (which is what I use every day) while still staying within a conservative power envelope.
PIC really does seem like the easiest step forward, the toolchain and IDE works on Linux and feels a bit less confusing than the AVR stuff. Since the PicKit1 that I have proved to be somewhat outdated (unsupported in MPLABX, and open-source GCC compiler won't compile), I'm back to square one. I guess I should just order both kits and write a blog entry about my findings.
« Last Edit: June 03, 2013, 04:15:32 pm by casper.bang »
Offline mark5009
« Reply #37 on: June 04, 2013, 04:12:15 am »
casper,
Just to add to the confusion :-) I would suggest a form follows function approach.  It is not considered usual these days, but, if you are in learning mode and don't have commercial requirements, then it can be a lot of fun.
For example, I am doing much as you are (EE, turned SE, turned architect, now getting back into the EE side of things non-professionally).  I have a PICkit 2 Dev Ket (it comes with a board), a stack of 8-bit PICs that I play with.  I like to use CAL with them.  It works.
I also have an Cortex-M3 board (the Olimex LPC-2103) that can use either the GNU toolchain or, my preference, Frank Sergant's Riscy Pygness Forth system.  And I run both against Win or Linux as needed.
Most of what I do can be done with an 8-bit micro, so I use the PICs.  Otherwise, it is the ARM.  And given that it is just for me, I can avoid the curse that is C (ducks ;-) )
 .. mark.
Offline mariush
« Reply #38 on: June 04, 2013, 04:33:08 am »
Casper, you can still download MPLAB IDE 8.91 from Microchip's website (see bottom of the page) :
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en019469&part=SW007002
It's not based on netbeans but it should still work reasonably well.
The old version should work with Pickit 1 just fine and you should have the hi-tech c compiler (the free version that doesn't optimize that well but has no code size limitations) and mpasm and others included in the zip file. If not I can send them to you somehow.
and you have here an archive of various compilers... http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023073
later edit: and in case it helps you out, here's all the software and code for that pickit 1 board you probably have  :  http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010053
« Last Edit: June 04, 2013, 04:42:19 am by mariush »
Offline poorchava
  • Troll Cave Electronics!
« Reply #39 on: June 04, 2013, 05:16:38 am »
Leave alone the AVR & PIC, go for ARM.
    • BangBits
« Reply #40 on: June 04, 2013, 06:42:48 am »
Hehe yeah C isn't exactly a modern development experience, although it has remained true to its heritage unlike C++. A modern systems programming language would of course be something like Google's Go. Like you, I also expect to be satisfied with what can be done with an 8-bit micro, there's enough hobby challenges for me in that. For one thing, how on earth is my PicKit1 board with a tiny 8-pin 12F765 PIC able to control the 8 red LED's individually - with VCC/GND tying up two pins, I'm missing at least two outputs?!  :-//
Thanks for all those great resources. I have had little luck getting it to work on Linux (though MPLAB IDE 8.91 and utilities actually starts up fine via CrossOver) so I will have to boot up a real Windows if I can find one somewhere. I actually went ahead and ordered an AVR programmer and a bunch of tiny AVR micros, but that doesn't mean I won't dig into PIC's as well - at least until I receive the parts.
Thanks again for the great feedback to all participants chiming in.
PS: I'm used to answering ridiculous "No I am not a terrorist" questions when traveling to the US, but it was news to me, that US export laws require Digi-Key to ask me what I am using the parts for! I reckon answering "Not for military, nuclear or strong encryption stuff" either expedited my order, or landed me on some silly watch list. Really fail to see the logic in these kind of questions, as if real terrorists answer truthfully to these?! |O
« Last Edit: June 04, 2013, 06:48:33 am by casper.bang »
Offline Kremmen
« Reply #41 on: June 04, 2013, 07:23:46 am »
Not knowing the PICs and their capabilites in detail, this may not apply to your particular chip but as a general practice: use SPI and 74xxx595 serial in-parallel out shift registers. Provided your MCU has the MOSI signal available that makes life semi easy; you can chain the 595s and push the data in at one end. I do this all the time to drive 7 segment displays, relay outputs, LED arrays and whatnot. You need 1 signal for the data, 1 for the clock and 1 or 2 for chip select/enable and thats it. Replacing 8 to (say) 32 outputs this waý is almost trivial and the upper limit is defined in practice only by the required update rate vs the cycle time you can achieve from the MCU. But a HW SPI can be real fast so i never found that limit yet.
And lacking a HW SPI, you can always bit bang the serial data.
Nothing sings like a kilovolt.
Dr W. Bishop
    • BangBits
« Reply #42 on: June 04, 2013, 08:19:48 am »
From a base 2, logically you are able to drive 2^4 states across the 4 output pins, but not control 12 individual LED's. However, the truth table reveals a third output state (Z) and the circuit diagram hints at a clever bi-directional setup. I guess there's a name for the technique, akin to multiplexing.
« Last Edit: June 04, 2013, 08:42:04 am by casper.bang »
Offline C
« Reply #43 on: June 04, 2013, 08:50:31 am »
hink like a serial port
pin 1 data out
pin 2 data in
pin 3 clock to shift data
pin 4 signal to capture data on input / latch the output data of shift regester
what goes out pin 1 could be ___ bits delayed coming back to pin 2
Serial memory with IO
split function of pin 4 to
pin 4 latch input data
pin 5 latch output data
just 5 pins and you could do almost any thing just not very fast.
Offline ptricks
« Reply #44 on: June 04, 2013, 12:01:47 pm »
Since you went with PIC I am going to recommend you either get via samples or buy some of the 16f1823 and here is why.
One of the most frustrating things when starting out is hard to follow data sheets. The sheets for the 16f1823 are so well done that I even wrote microchip commending whoever wrote them because it is how all data sheets should be written. Everything is covered in detail with code examples. The chips are also pretty cheap and very capable without confusing you with a ton of peripherals .
Offline Kremmen
« Reply #45 on: June 04, 2013, 12:37:36 pm »
Yep, also for AVRs, just define the pin as input and drive it to '0' and it is 3-stated. Standard stuff.
But my point with the shift register was something else. It is not just a clever trick, it is a genuinely useful technique widely applied when one is short on pins or they are better applied elsewhere.
Dr W. Bishop
    • BangBits
« Reply #46 on: June 04, 2013, 12:58:58 pm »
No doubt, there are all sorts of useful serial multiplexing techniques hooking up latches and shifters, I was just puzzled by the elegant no-cost 4 output to 12 LED solution... feels like Fundamental Friday material.  ;)
Offline selkathguy
« Reply #47 on: June 04, 2013, 01:15:35 pm »
Goodness this thread blew up.  ::)
I had a feeling when someone was asking about what micros to try out that this might happen.   I'm very new to the whole thing, but for the specific project I'm working on, I chose an AVR 32bit micro because it has a DSP instruction set and everything else I need in one go.  (Doing FFT instructions in a couple cycles is awesome).  But that's what it's about, OP.  It's about looking at the feature sets of all kinds of micros and figuring out what works best for your application.  After wrapping my head around various source library code for an AT32UC3B, I'm starting to understand it and all the witchcraft actually makes sense and works well in their programming environment.   Honestly, for the cost I would try out both PICs and AVRs if you can.  To make an insanely gross overgeneralization:  PICs to me seem great if you want to lash up something quickly because it's very straight-forward and requires very very little C code to do something simple.  AVRs tend to require a bit more reading of datasheets to avoid 'gotchyas', but are quite powerful in what you can accomplish on such a small device.  PICs can be powerful too, you'll just have to get a feel for which is better for your application.  Execution speed isn't always the only metric; it's often the feature sets like Direct Memory Access and (for example), the Digital Signal Processing instrucions that I needed in my project.
I know that's vague but I hope it helps give some insight.
Offline MacAttak
« Reply #48 on: June 04, 2013, 06:12:41 pm »
That name is "Charlieplexing".
http://en.wikipedia.org/wiki/Charlieplexing
Offline mariush
« Reply #49 on: June 04, 2013, 06:24:01 pm »
There are also some other neat tricks explained by microchip in their app notes and guides.
See the following:
http://savedonthe.net/a/Tips_n_Tricks_01146b.pdf
http://savedonthe.net/a/Tips_n_Tricks_40040C.pdf
Lots of neat tricks for low pin count, keyboards, multiplexing etc explained pretty good.
